Splitting multi-sheet documentation into single idw files
idealogicERZYZ
idealogicERZYZ
I found a code on the forum that allows me to split a multi-sheet file into single idw files. The code works if there is only one view in the sheet, then the code saves the file to the name of the source file of this view, but if there are more views, the code saves to the name of the default template file. Please help me get the appropriate name from the base view from a sheet with n views.
 Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'Set oDrawDoc = ThisApplication.ActiveDocument
    Dim str1 As String
    str1 = oDrawDoc.FullFileName
    Dim s As Sheet
    For Each s In oDrawDoc.Sheets
        s.Activate
        Dim oDrawDoc1 As DrawingDocument
        'Set oDrawDoc1 = ThisApplication.Documents.Add(kDrawingDocumentObject)
        Call s.CopyTo(oDrawDoc1)
        oDrawDoc1.Sheets.Item(1).Delete
        Dim Str As String
        Str = s.DrawingViews.Item(1).ReferencedDocumentDescriptor.FullDocumentName
        Str = Right(Str, Len(Str) - InStrRev(Str, "\"))
        Str = Left(Str, Len(Str) - 4)
        Dim fname As String
		 fname = Replace(str1, ".idw", "_" & Replace(s.Name, ":", "_") & "_" & Str & ".idw")
	  Next
Single view sheet
Sheet with multiple views
thx E
cidhelp
Hi @idealogicERZYZ ,
in your iLogic-Code the filename is created as string fname, but the file is not saved with this filename.
Add
oDrawDoc1.SaveAs(fname, False)
before the last Next-line, and each file will be saved with this name.
idealogicERZYZ
Yes, that's right, I don't really need the fname variable, I need to save to a file whose name is the file name in the base view.
In this code the fanme variable takes the sheet name and the source file name and I only need the source file name ipt or iam
