Split tool using ilogic
manu.marjanen
manu.marjanen
How can i Split all the solids at once and keep the default side?
Splitting tool is ExtrusionSrf2
Splitting needs to work even if the number of solids varies.
L.Greft
You can't split multiple solids at once (as far as I know). But looking at your image, wouldn't it be easier to use an extrusion to cut everything in between the blue circle and ExtrusionSrf2
Check out my ideas: https://autode.sk/2TKe6LH
