Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Split a 3dline with Planes (3D sketch)
Ktelang
Ktelang
Is it possible to split a 3d line with planes
I am not able to find a Split method on Sketchline3d
{Code}
Sub Split_Lines()
If ThisApplication.Documents.Count = 0 Then Exit Sub
    If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then Exit Sub
' Check to make sure a sketch is active.
If Not TypeOf ThisApplication.ActiveEditObject Is Sketch3D Then
  MsgBox "A sketch must be active."
  Exit Sub
Dim oPartCompdef As PartComponentDefinition
Set oPartCompdef = ThisApplication.ActiveDocument.ComponentDefinition
' Set a reference to the active sketch.
Dim oSketch As Sketch3D
Set oSketch = ThisApplication.ActiveEditObject
' Set a reference to the transient geometry collection.
Dim oTransGeom As TransientGeometry
Set oTransGeom = ThisApplication.TransientGeometry
Dim SketchLine As SketchLine3D
Dim WorkPl As WorkPlane
Dim i As Integer
For Each SketchLine In oSketch.SketchLines3D
For Each WorkPl In oPartCompdef.WorkPlanes
'What should be done here ??
Next
Next
End Sub
{Code}
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Vladimir.Ananyev
Unlike SketchSpline3D object  Sketchline3d has no Split method. But this function can be easily created.
Here is simple workaround. Create sketch line 3D intersected Y-Z base work plane and run the following VBA sample code.
Sub Split_Line_By_Workplane()
  Dim oTG As TransientGeometry
  Set oTG = ThisApplication.TransientGeometry
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim oDef As PartComponentDefinition
  Set oDef = oDoc.ComponentDefinition
  Dim oSketch3D As Sketch3D
  Set oSketch3D = oDef.Sketches3D.Item(1)
  'some workplane
  Dim oWP As WorkPlane
  Set oWP = oDef.WorkPlanes.Item(1)
  'some SketchLine3D object
  Dim oSketchLine3D As SketchLine3D
  Set oSketchLine3D = oSketch3D.SketchLines3D.Item(1)
  '--- find intersection point ---
  Dim oLineSegment As LineSegment
  Set oLineSegment = oSketchLine3D.Geometry
  Dim oObjectsEnumerator As ObjectsEnumerator
  Set oObjectsEnumerator = oLineSegment.IntersectWithSurface(oWP.Plane)
  If oObjectsEnumerator Is Nothing Then
    MsgBox "No intersection"
    Exit Sub
  'sketch 3D-points collection
  Dim oSkPoints3d As SketchPoints3D
  Set oSkPoints3d = oSketch3D.SketchPoints3D
  'SketchPoint3D at the intersection point
  Dim oPoint As Point
  Set oPoint = oObjectsEnumerator.Item(1)
  Dim oP0 As SketchPoint3D
  Set oP0 = oSkPoints3d.Add(oPoint)
  oP0.HoleCenter = False
  'start point
  Dim oP1 As SketchPoint3D
  Set oP1 = oSketchLine3D.StartSketchPoint
  'end point
  Dim oP2 As SketchPoint3D
  Set oP2 = oSketchLine3D.EndSketchPoint
  'save end point in the new point
  Dim oP3 As SketchPoint3D
  Set oP3 = oSkPoints3d.Add(oSketchLine3D.EndSketchPoint.Geometry)
  oP3.HoleCenter = False
  'shorten source line moving
  'old end point to the intersection point
  Call oP2.ConnectTo(oP0)
  'create the second line
  Dim oSketchLine3d2 As SketchLine3D
  Set oSketchLine3d2 = oSketch3D.SketchLines3D.AddByTwoPoints(oP0, oP3)
  'add collinear constraint if needed
  Dim oGeomConstraints As GeometricConstraints3D
  Set oGeomConstraints = oSketch3D.GeometricConstraints3D
  Call oGeomConstraints.AddCollinear(oSketchLine3D, oSketchLine3d2)
End Sub
 Hope the idea is clear.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Ktelang
Thanks Vladimir,
It is exactly what I wanted. I understood the concept
Thanks again
