i try to Split a 3D Curve.
I took a similar Scrip for Split2D Curve, which works for 2D curves, but my Goal is to Split a 3D Curve.
I use the SDKInventorAddIn in Visual Studio
Public Sub SampleCommandFunction()
Dim partDoc As PartDocument
partDoc = g_inventorApplication.ActiveDocument
Dim spline As Object
spline = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketch3DCurveFilter, "Select 3d spline")
' Get the spline geometry from the entity.
Dim splineCurve As BSplineCurve
splineCurve = spline.Geometry
' Determine the parameter value for geometric midpoint of the curve.
Dim curveEval As CurveEvaluator
curveEval = splineCurve.Evaluator
Dim startParam As Double
Dim endParam As Double
Call curveEval.GetParamExtents(startParam, endParam)
Dim midParam As Double
Call curveEval.GetParamAtLength(startParam, spline.Length / 2, midParam)
' Split the curve.
Dim curve1 As BSplineCurve
Dim curve2 As BSplineCurve
Call splineCurve.Split(midParam, curve1, curve2)
' Create new sketch curves using the extracted splines.
Dim splineSketch As Sketch3D
splineSketch = spline.Parent
Call splineSketch.SketchFixedSplines.Add(curve1)
Call splineSketch.SketchFixedSplines.Add(curve2)
' Delete the original curve.
spline.Delete
End Sub
I can select a Curve, but without any Result.
Actually my Goal is to Split the Curve with equal Length and also choose the quantity, but first only in Middle
Any Suggestion.
