Specialist Design Drafts Person
I need to design a drive wheel of a cross travel on a overhead crane. The Engineer want the drive wheel to be the pinion and then I have to install a rack on the I beam flange.
Regards
Wally Badenhorst
WCrihfield
So...what specifically do you need from this forum?
Are you hoping someone here will design this wheel for you, based on the given info?
Perhaps your question would be better served on the main Inventor Forum?
Wesley Crihfield
(Not an Autodesk Employee)
