sorting of the tree structure
Message 1 of 19
Is there a program which would alphabetically sort the components of an
assembly in the navigator?
Thx
Dom
Replies (18)
Message 2 of 19
See the attached text file for a program that does the alpha-sorting. This
is also included as a command in the 'Assembly Tools' SDK sample delivered
with R11.
Sanjay-
"Dominique" < wrote in message
news:5184312@discussion.autodesk.com...
Thx
Dom
Message 3 of 19
Thanks, it work fine.
Regards
Dom
"Sanjay Ramaswamy (Autodesk)" a écrit dans
le message de news: 5184999@discussion.autodesk.com...
with R11.
Sanjay-
Thx
Dom
Message 4 of 19
So what is the trick to running this code. Every time I try
to run it in an assembly, all I get is a "Sorting Failed"
message!
Bob S.
Message 5 of 19
Which release are you on? There were a few problems in R10 that were fixed
in R11. Could you try it with different assemblies, perhaps simple ones to
begin with?
Sanjay-
"Bob S." wrote in message
news:5185755@discussion.autodesk.com...
message!
Bob S.
Message 6 of 19
I'm running it in R11 SP0. Not a very complex assembly. I will try
it on some other simpler ones (20 components, approx) and let you
know. Most of these assemblies are probably migrated from R10 if
that matters.
Bob S.
Message 7 of 19
Sanjay,
I was able to get it to run on a couple very simple
assemblies at this point (up to 5 component occurrences)
but it chokes on one with approx 40 component occurrences.
At first I thought it might be due to subassemblies, but
one of the small ones I ran it on also had subassemblies in it.
Again, R11.
Bob S.
Message 8 of 19
It seems to work fine with the 'Engine.iam' sample delivered with Inventor
(this has over 40 occurrences). Would you be able to narrow down the problem
with the assembly you are using? By perhaps deleting some occurrences?
Sanjay-
news:5186311@discussion.autodesk.com...
Sanjay,
Again, R11.
Bob S.
Message 9 of 19
I don't really have the time to play with it right now.
Maybe I could send you an assembly that it chokes on?
Bob S.
Message 10 of 19
Sure. sanjayDOTramaswamyATautodeskDOTcom
Sanjay-
news:5186427@discussion.autodesk.com...
Bob S.
Message 11 of 19
Sanjay,
I tried sending you a zipfile, but it got kicked back to me.
I sent another email stating that and I have not heard
from you. Please let me know if you got that email.
Bob S
> Sanjay-
> Bob S.
Message 12 of 19
I've posted a small assembly example in customer-files that
fails to sort the browser nodes in case anyone thinks they
can figure out the problem.
Bob S.
Message 13 of 19
Why doesnt it run in IV 10?
Message 14 of 19
The ability to reorder the browser nodes wasn't supported until Inventor 11.
Brian Ekins
Autodesk Inventor API
wrote in message news:5271404@discussion.autodesk.com...
Message 15 of 19
You mean reorder through the API?
Message 16 of 19
Wrong! I had a macro that reordered the browser nodes in 10. But
now it fails in 11. The implementation of it has changed, but it
WAS there in 10.
Bob
Message 17 of 19
Can you share your code for the IV10 macro?
Message 18 of 19
rschader
I guess I don't see why not since it doesn't seem to work in 11 anyway. It's also rather slow, but it did work at one time. The zip file contains both a ivb and an exported bas file in case the ivb file isn't compatible. The main sub is probably NOT named correctly for function, it is called QueryModelTree (probably because I copied a sample to start with. There is also extra sorting functions in this I borrowed that didn't get used, or I couldn't get them to work. Let me know if it does indeed still work on 10, if you could. Thanks,
Bob Schader
Message 19 of 19
Hi Bob,
You're right. I quickly forget when new features came in. The Reorder
method on the browser has been around for a while. The reason I was
thinking it showed up in 11 was because we showed a demonstration of
reordering the assembly browser as part of the demos of what's new in
Inventor 11. In this case it wasn't the reorder functionality that was new
but some changes in assembly that allowed it to work correctly there.
Brian Ekins
news:5271519@discussion.autodesk.com...
WAS there in 10.
Bob
> 11.
