sorting bom problem
sorting bom problem
GeorgK
Advisor Advisor
Message 1 of 8
sorting bom problem
GeorgK
Hello together,
I have a problem to sort my drawing bom. The first step is to sort the "part number" ascending, which is working.
Public Sub PartListEdit()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the first parts list on the active sheet.
    ' This assumes that a parts list is on the active sheet.
    Dim oPartList As PartsList
    Set oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
    ' Iterate through the contents of the parts list.
    Dim i As Long
    For i = 1 To oPartList.PartsListRows.Count
        ' Get the current row.
        Dim oRow As PartsListRow
        Set oRow = oPartList.PartsListRows.Item(i)
        ' Iterate through each column in the row.
        Dim j As Long
        For j = 1 To oPartList.PartsListColumns.Count
            ' Get the current cell.
            Dim oCell As PartsListCell
            Set oCell = oRow.Item(j)
            If oPartList.PartsListColumns.Item(j).Title  "Part number" Then
                'Do some work
        Next
    Next
End Sub
In the next step I would like to sort the parts with the name from 1 to x
  1. S000AxxxxxxxxxP001
  2. S000AxxxxxxxxxP002
  3. S000AxxxxxxxxxP003
xxxxxxxxx could be numbers or text.
The remaining parts should get a number from 100 to xx
How could I do this?
Thank you
Georg
Replies (7)
Message 2 of 8
GeorgK
The bom columns:
No.; Qty.; Part number; Title
Message 3 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
 @GeorgK ,
Hoping that below iLogic code may be helpful to sort substring of string.
Dim list1() As String = {"abc0002", "aab0001", "abb0005", "aaa0003", "aed0004"}
Dim result = list1.OrderBy(Function(q) q.Substring(5)).ToArray
For Each s As String In result
    MessageBox.Show(s)
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 4 of 8
GeorgK
Hello @chandra.shekar.g ,
thank you for the sample. It's not the problem to sort the list. The problem is to sort the partlist. Please could you send me an example.
Thank you
Georg
Message 5 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK ,
Please send me sample partslist with expected result and make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 6 of 8
GeorgK
Sorted partlist:
But there could also some parts with a or b at the beginning which should be positioned after the S00xxxxxxPxx parts.
Message 7 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK ,
Hoping that below iLogic code may be helpful to sort part numbers.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
Dim oPartslist As PartsList
oPartslist = oSheet.PartsLists.Item(1)
Dim myList As New List(Of String)()
Dim i As Integer
For Each oRow In oPartslist.PartsListRows
	If oRow.Item(3).Value.Length = 13 Then
		myList.Add(oRow.Item(3).Value)
Next
Dim list() As String = myList.ToArray()
Dim result = list.OrderBy(Function(q) q.Substring(11)).ToArray
i = 1
		If s = oRow.Item(3).Value Then
			Call oRow.Reposition(i)
			i = i + 1
	Next
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 8
GeorgK
thank you very much. I didn't thought about Reposition the row.
Georg
