Sort parts List based on Part Number
donaldleigh
Message 1 of 8
donaldleigh
Hi all
I have found and modified the below rule to sort our parts list based on the part number.
The part number can be in several formats.
Type 1 - Drawing number "18000-01-01" always 11 characters long
Type 2 - DXF number "DXF 18000-01-A" always starts with DXF
Type 3 - Part Number "11111" always 5 characters long
Type 4 - anything else.
I keep getting an error with looking at the number of characters or looking for the 1st 3 characters of the part number
Can someone please point me in the right direction.
SyntaxEditor Code Snippet
' Set a reference to the drawing document.' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the first parts list on the active sheet.' This assumes that a parts list is on the active sheet.
Dim oPartList As PartsList
oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
Dim oPartNumber As PartsListCell
Dim oType As PartsListCell
'Dim oPartNumberLength As Integer'Dim invCharPosition As Integer
' Iterate through the contents of the parts list.
Dim i As Long
For i = 1 To oPartList.PartsListRows.Count
    'Get value from PartNumber column
    oPartNumber = oPartList.PartsListRows.Item(i).Item("DWG/PART No.")
    oType = oPartList.PartsListRows.Item(i).Item("PART TYPE")
    oPartNumberLength = Len(oPartNumber)
    oPartNumberStart = Left(oPartNumber,3)
        If oPartNumberLength = 11 Then
        oType.Value = "DWG"
        Else If oPartNumberStart = "DXF" Then
        oType.Value = "DXF"
        Else If oPartNumberLength = 5 Then
        oType.Value = "STD"
        Else
        oType.Value = "Other"
Next
oPartList.Sort("PART TYPE")
oPartList.Renumber
oPartList.SaveItemOverridesToBOM
Cheers
Donald
Inventor 2014
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Try below iLogic code to get first 3 letters from a string.
oPartNumberStart = oPartNumber.Substring(0,3)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
donaldleigh
Hi @chandra.shekar.g
I get the following error
Public member 'Substring' on type 'PartsListCell' not found.
Donald
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
Some times oPartNumber would be a numeric or double. Try below code.
oPartNumberStart = oPartNumber.ToString().Substring(0,3)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
donaldleigh
This returns the text "System._ComObect" with the number is changed from 3 to 19
Donald
Message 6 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@donaldleigh,
I thought oPartNumber was string. But it is a type of PartsList. Try below code.
oPartNumberStart = oPartNumber.Value.ToString().Substring(0,3)
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 7 of 8
donaldleigh
That worked for finding the 1st 3 characters off the part number. thanks
But now I also need to find how many characters are in the part number to work out if its a Drawing Number or Part Number.
Donald
Message 8 of 8
donaldleigh
I got it sorted
Here is my final code. Thanks for your help with this.
Dim i As Long
    'Find the 1st 3 characters of the Part Number
    oPartNumberDXF = oPartNumber.Value.ToString().Substring(0,3)
    'Return the Part Number as a string
    oPartNumberValue = oPartNumber.Value.ToString()
    'Return the number of characters in the Part Number
    oPartNumberLength = Len(oPartNumberValue)
        If oPartNumberDXF = "DXF" Then
        oType.Value = "DXF"
        ElseIf oPartNumberLength = 11 Then
        oType.Value = "DWG"
        oType.Value = "STD"
        Else
Next
oPartList.Sort("PART TYPE", 1, "DWG/PART No.", 1)
oPartList.Renumber
