sort parameter values
Hi folks,
Im writing some code and found on google some VB.net sorting code but when i try to use it gives me an error.
ERROR: sort is not declared. The item may not be accessible as a result of the associated security level
anyone who knows what this means, what im i doing wrong?
my code:
SyntaxEditor Code Snippet
Dim MyArrayList As New ArrayList
MyArrayList.add(X_Afstand_1_Ruit)
MyArrayList.add(X_Afstand_2_Ruit)
MyArrayList.add(X_Afstand_3_Ruit)
MyArrayList.add(X_Afstand_4_Ruit)
Sort(MyArrayList)
For Each Str As Double In MyArrayList
    MsgBox(Str)
Next
Or if you have a better code for sorting values please tell me.
The thing is i always want the middle 2 values from the list no matter what but they need to be in order. Because i want to use them in mathformulas
Thanks in advance
HermJan.Otterman
Hello Lowie,
this works:
Dim MyArrayList(3) As Double
MyArrayList(0) = 43
MyArrayList(1) = 33
MyArrayList(2) = 6
MyArrayList(3) = 7
Array.Sort(MyArrayList)
    MsgBox(Str)
Next
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
thank you very much made my code a bit easier
