solid bodies
solid bodies
Cosmin_V
solid bodies
Cosmin_V
Hi Everybody
I have a piece of rule I need a little help with it.
The rule should check all parts, and if the part is in "reference" then I need all solid bodies to be visible in that part.
now it turns the visibility on always.
Can this be done?
Dim openDoc As Document
openDoc = ThisDoc.Document
Dim oCompDef As Inventor.ComponentDefinition = openDoc.ComponentDefinition
	Dim oAssyDoc As AssemblyDocument
		oAssyDoc = ThisApplication.ActiveDocument
		Dim oDoc As Document = ThisDoc.Document
			For Each oDoc In oAssyDoc.AllReferencedDocuments
		        For Each SB In oDoc.ComponentDefinition.SurfaceBodies
					For Each oOcc As ComponentOccurrence In oCompDef.Occurrences.AllLeafOccurrences
						If oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
							SB.Visible = True
						If oOcc.BOMStructure <> BOMStructureEnum.kReferenceBOMStructure Then
					Next
		        Next
			Next
Andrii_Humeniuk
Hi @Cosmin_V . Please try this code:
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oOccs As ComponentOccurrences = oAsmDoc.ComponentDefinition.Occurrences
For Each oRefDoc As Document In oAsmDoc.AllReferencedDocuments
	If oOccs.AllReferencedOccurrences(oRefDoc).Count = 0 Or _
		Not oRefDoc.IsModifiable Or
		Not oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Continue For
	Dim oPartDoc As PartDocument = oRefDoc
	Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
	If oPartDef.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
		For i As Integer = 1 To oPartDef.SurfaceBodies.Count
			oPartDef.SurfaceBodies(i).Visible = True
		Next
	For Each oOcc As ComponentOccurrence In oOccs.AllReferencedOccurrences(oRefDoc)
			Next
	Next
Next
Update.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Cosmin_V
tanks @Andrii_Humeniuk
It is almost good, what if the part it is "Normal"
But in to the assembly level it is set to be in "reference"?
Andrii_Humeniuk
I found what the problem was. Try this code:
		Next
				oOcc.SurfaceBodies(i).Visible = True
			Next
	Next
Next
