snapping to geometry in different sketches
revyakin
Message 1 of 1
revyakin
Hi all --
I realize that this is probably be a trivial issue, and it has been asked before. I am trying to use the line tool in sketch 2 to re-trace parts of geometry (vertices, circle centres etc) in sketch 1, so that I can later extrude them in sketch 2. I have the autoproject option enabled in Application options (it was enabled as a default anyway). When I roll over the mouse onto vertices etc, individual points get highlighted, but when I try to create geometries instead, snapping does not work anymore.
It appears that when I create a brand new part, with sketches 1 and 2, snapping does work, but I am hoping to find the issue in the original problematic file (attached)
Thank you in advance!
Replies (0)
