slow code because it that time to open an excel sheet .. is that a way not have to reopen the sheet each time ?
Darkforce_the_ilogic_guy
Advisor Advisor
I have a code that need to read some info form a excel fil... my problem is that this is very slow. I use excel because i have the skill and it is easy to see and add information to it. Is there a way to make it faster ?
A.Acheson
Can you show the code your using? Depending on your code running an excel file should open in 1.8 to 2 seconds. There may be other issues at play. Also check if unecessary addin are removed from excel document like 3d  connection mouse etc. Check them off and test.
Regards
Alan
Sub Main()
	Dim partnumber
	ExcelPath = "C:\Working Folder\CAD\Kallesoe\Kallesoe iLogic\Underdevelopment\Accessories Finder\Accessories Filder.xlsm"
	ExcelSheet = "Assessoires"
'ask you to select spareparts
	Dim oRefDoc As ComponentOccurrence = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Select FG component")
'setBL(oRefDoc)
partnumber = iProperties.Value(oRefDoc.Name, "Project", "Part Number")
GoExcel.Open(ExcelPath, ExcelSheet)
Dim i
i=2
Do Until i > 600
    'MsgBox("Row A " & GoExcel.CellValue(ExcelPath , ExcelSheet, "A" & i) & " " & partnumber  )
	If GoExcel.CellValue(ExcelPath , ExcelSheet, "A" & i) = partnumber Then
'test = test & " " & GoExcel.CellValue(ExcelPath, ExcelSheet, "B" & i) & "	" & GoExcel.CellValue(ExcelPath, ExcelSheet, "C" & i) & vbLf
test = test & GoExcel.CellValue(ExcelPath, ExcelSheet, "B" & i) & " OR "
Else
    i = i + 1
Loop
GoExcel.Close
If (test) <> "" Then
	'MessageBox.Show(test, "Accessories for " & partnumber)
Else
	MsgBox("No Accessries found")
'MsgBox(test.Tostring.count)
test = Left(test, test.Tostring.count-4)
filecreate(test)
End Sub
Sub setBL(oOcc As ComponentOccurrence)
	Try
		partnumber = iProperties.Value(oOcc.Name, "Project", "Part Number")
		'InventorVb.DocumentUpdate()
	Catch
		'iLogicVb.RunExternalRule("EditLengthOfOldTypeProfile")
	End Try
	'msgbox (partnumber)
End Sub
Sub filecreate(txt)
	'%appdata%\Autodesk\VaultCommon\Servers\Services_Security_1_7_2019\cadsrv\Vaults\Kallesoe\Searches
'oWrite = System.IO.File.CreateText("C:\Users\bt\Desktop\" & "TestSearch")
oWrite = System.IO.File.CreateText("C:\Users\bt\AppData\Roaming\Autodesk\VaultCommon\Servers\Services_Security_1_7_2019\cadsrv\Vaults\Kallesoe\Searches\" & "TestSearch")
'&#34;
Dim nr3 = txt
Clipboard.SetText(nr3)
Dim line1 = "<?xml version=""1.0""?>"
Dim line2 = "<SearchParameters xmlns:xsd=""http://www.w3.org/2001/XMLSchema"" xmlns:xsi=""http://www.w3.org/2001/XMLSchema-instance"" TypeName=""Connectivity.Explorer.Framework.IExplorerObject"" LatestOnly=""true"" SearchSubfolders=""true"" SearchFullContent=""false"" IsFolder=""true"" Id=""d772de38-ccc7-42c0-b771-59b86cac6627"" xmlns=""http://schemas.autodesk.com/msd/plm/SearchParameters/2009-07-23"">"
Dim line3 = "  <SearchConditions>"
Dim line4 = "    <SearchCondition Value=""" & nr3 & """ PromptForValue=""false"" PropertyKey=""PartNumber"">"
Dim line5 = "      <Type>CONTAINS</Type>"
Dim line6 = "    </SearchCondition>"
Dim line7 = "  </SearchConditions>"
Dim line8 = "  <SearchLocations>"
Dim line9 = "    <Locations URI=""vaultfolderpath:$/Designs/Tegninger"" />"
Dim line10 = "    <Locations URI=""vaultfolderpath:$/Designs/Standard components"" />"
Dim line11 = "  </SearchLocations>"
Dim line12 = "</SearchParameters>"
oWrite.WriteLine(line1)
oWrite.WriteLine(line2)
oWrite.WriteLine(line3)
oWrite.WriteLine(line4)
oWrite.WriteLine(line5)
oWrite.WriteLine(line6)
oWrite.WriteLine(line7)
oWrite.WriteLine(line8)
oWrite.WriteLine(line9)
oWrite.WriteLine(line10)
oWrite.WriteLine(line11)
oWrite.WriteLine(line12)
oWrite.Close()
'MsgBox("--> "" <--")
'open the file
'ThisDoc.Launch("C:\Users\"username Here"\AppData\Roaming\Autodesk\VaultCommon\Servers\Services_Security_1_7_2019\cadsrv\Vaults\Kallesoe\Searches\" & "TestSearch")
End Sub
This is the complete code.. it have about 150 lines in Excel
kresh.bell
sorry for the intrusion, I had extremely big problems with excel. I finally found the cause of the problem. One addin in excel (opening tabs instead new windows) caused the problem, also some other addins but to a lesser extent
Curtis_Waguespack
Hi @Darkforce_the_ilogic_guy
You might try using something like this, so that it the code opens the Excel file, and then just uses it ( rather than opening it again) .
I hope this helps.
Curtis
i = 2
Do Until i > 600
	If GoExcel.CellValue("A" & i ) = partnumber Then
		test = test & GoExcel.CellValue("B" & i) & " OR "
	i = i + 1
Loop
GoExcel.Close
A.Acheson
Here is one such COM Addin  and the negative effect is approx 3 secs.
Here is a testing code for both go excel and Excel dll method. Both seem to be equally as fast with this simple task.
'Option Explicit On
'AddReference "microsoft.office.interop.excel.dll"
'Imports XL = Microsoft.Office.Interop.Excel
Sub Main
	'https://forums.autodesk.com/t5/inventor-forum/ilogic-measure-time-elapsed-during-run-rule/td-p/5578813
	Dim stopWatch As New Stopwatch()
	stopWatch.Start()
	Call ExcelApplication_dll()
	'Call Go_Excel()
	stopWatch.Stop()
	' Get the elapsed time as a TimeSpan value.
	Dim ts As TimeSpan = stopWatch.Elapsed
	' Format and display the TimeSpan value.
	Dim elapsedTime As String = String.Format("{0:00}:{1:00}:{2:00}.{3:00}", ts.Hours, ts.Minutes, ts.Seconds, ts.Milliseconds / 10)
	MsgBox("RunTime " & elapsedTime)
End Sub
'5.45 5.55 secs 3d Connexion on, 3.04,2.86,2.36 3d Connexion off
Sub ExcelApplication_dll()
	Dim i As Integer = 0
	Dim xlApp As XL.Application = CreateObject("Excel.Application")
	Dim xlWb As XL.Workbook = xlApp.Workbooks.Open("C:\Users\BOM.xlsx")
	'comment out or change to false in order to not show Excel
	'xlApp.Visible = True
	Dim xlWs As XL.Worksheet = xlApp.ActiveWorkbook.ActiveSheet
	Do Until i > 600
		i = i + 1
		xlWs.Range("A" & i).Value = i
	Loop
	xlWb.Save
	xlWb.Close
	'xlApp.Quit
End Sub
'5.3 Secs 3d Connexion on, 2.89,2.62,3.07-3d Connexion off
Sub Go_Excel()
	GoExcel.Open("C:\Users\BOM.xlsx", "Sheet1")
	Do Until i > 600
		i = i + 1
		GoExcel.CellValue("A" & i ) = i
	Loop
	GoExcel.Save
	GoExcel.Close
End Sub
Regards
Alan
