SLOT MARKING ON BEND LINES.
anuj16797
anuj16797
Hi all,
I need help as I need to create slots on each bend line on the back of a flat pattern on both sides (left and right).
I have attached a  snap of the dimensions (extrusion require is 1/32") of the slot from the bend lines.
please help me to create an ilogic as soon as possible for the same.
@Curtis_Waguespack
@mcgyvr
@GeorgK
@tkddud711
@chandra.shekar.g
@JDMather
@ccarreiras
@Galaxybane
@blandb
dalton98
Hello. This is a bit sloppy but it would require a lot more time fine tuning. It works for the part you provided but might not for other ones.
On Error Resume Next
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oSMCompDef As SheetMetalComponentDefinition
oSMCompDef = oPartDoc.ComponentDefinition
Dim oSketch As PlanarSketch
oSketch = oSMCompDef.FlatPattern.Sketches.Add(oSMCompDef.FlatPattern.TopFace, False)
'point roughly at the center of flat pattern
Dim oPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(5, 5)
For Each oEdge As Edge In oSMCompDef.FlatPattern.GetEdgesOfType((FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge))
	'create two points at end point of bend lines then create slot
	Dim oSketchLine As SketchLine = oSketch.AddByProjectingEntity(oEdge)
	Dim oSketchPoint As SketchPoint = oSketch.SketchPoints.Add(oPoint)
	oSketch.GeometricConstraints.AddCoincident(oSketchPoint, oSketchLine)
	oDimConstraint = oSketch.DimensionConstraints.AddTwoPointDistance(oSketchLine.EndSketchPoint, oSketchPoint, DimensionOrientationEnum.kAlignedDim, oPoint)
	oDimConstraint.Parameter.Value = 3 / 32 * 2.54
	Dim oSketchPoint1 As SketchPoint = oSketch.SketchPoints.Add(oPoint)
	oSketch.GeometricConstraints.AddCoincident(oSketchPoint1, oSketchLine)
	oDimConstraint1 = oSketch.DimensionConstraints.AddTwoPointDistance(oSketchPoint, oSketchPoint1, DimensionOrientationEnum.kAlignedDim, oPoint)
	oDimConstraint1.Parameter.Value = 1.5 * 2.54
	oSlot = oSketch.AddStraightSlotByOverall(oSketchPoint, oSketchPoint1, 0.5 * 2.54)
	'create two points at start point of bend lines then create slot
	Dim oSketchPoint2 As SketchPoint = oSketch.SketchPoints.Add(oPoint)
	oSketch.GeometricConstraints.AddCoincident(oSketchPoint2, oSketchLine)
	oDimConstraint2 = oSketch.DimensionConstraints.AddTwoPointDistance(oSketchLine.StartSketchPoint, oSketchPoint2, DimensionOrientationEnum.kAlignedDim, oPoint)
	oDimConstraint2.Parameter.Value = 3 / 32 * 2.54
	Dim oSketchPoint3 As SketchPoint = oSketch.SketchPoints.Add(oPoint)
	oSketch.GeometricConstraints.AddCoincident(oSketchPoint3, oSketchLine)
	oDimConstraint3 = oSketch.DimensionConstraints.AddTwoPointDistance(oSketchPoint2, oSketchPoint3, DimensionOrientationEnum.kAlignedDim, oPoint)
	oDimConstraint3.Parameter.Value = 1.5 * 2.54
	oSlot = oSketch.AddStraightSlotByOverall(oSketchPoint2, oSketchPoint3, 0.5 * 2.54)
Next
'run again for other direction bends???
'For Each oEdge As Edge In oSMCompDef.FlatPattern.GetEdgesOfType((FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge))
'	'copy above
'Next
oPartDoc.Update
'create extrusion
Dim objCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim oProfile As Profile = oSketch.Profiles.AddForSolid'(False, objCol)
oExtrudeDef = oPartDoc.ComponentDefinition.FlatPattern.Features.ExtrudeFeatures.CreateExtrudeDefinition(oProfile, kCutOperation)
oExtrudeDef.SetDistanceExtent(1 / 32 * 2.54, kNegativeExtentDirection)
oExtrude = oPartDoc.ComponentDefinition.FlatPattern.Features.ExtrudeFeatures.Add(oExtrudeDef)
