Skip Read-only or not Modifiable file.
DewayneH
Message 1 of 8
DewayneH
I have a simple rule to check for and add new properties to existing part and assembly files "Before Save".
Basically, I don't want the properties added to drawings or read-only files.
My issue is, I am unable to prevent the properties being written to read-only files.
The suggestion I tried was using "IsModifiable", but it seems to have no affect whether the file is read-only or not.
What did I do wrong?
Dim doc As Document
doc = ThisApplication.ActiveDocument
'Checks if document is drawing.
If doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
'Do Nothing
Else If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject And doc.IsModifiable = True Or
doc.DocumentType = DocumentTypeEnum.kPartDocumentObject And doc.IsModifiable = True Then
'Test if properties exist.
Try
	iProperties.Value("Custom", "Component Class") = iProperties.Value("Custom", "Component Class")
	iProperties.Value("Custom", "Spare Part") = iProperties.Value("Custom", "Spare Part")
	'Create properties with default value if they don't exist
Catch
	iProperties.Value("Custom", "Component Class") = "MANUFACTURED"
	iProperties.Value("Custom", "Spare Part") = "NO"
End Try
Dewayne
Inventor Pro 2023
Vault Pro 2023
Replies (7)
Message 2 of 8
FINET_Laurent
May this helps out : https://forums.autodesk.com/t5/inventor-customization/ilogic-check-if-public-document-is-readonly/td...
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 8
Sergio.D.Suárez
Hi, could you try something similar to what I show you
Dim doc As Document = ThisApplication.ActiveDocument
'Checks if document is not drawing.
If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
	doc.DocumentType = DocumentTypeEnum.kPartDocumentObject  Then
	Dim fi As New System.IO.FileInfo(doc.FullFileName)
	If fi.IsReadOnly = False Then
		Try
		Catch
		End Try
 I hope this can help you. Greetings!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 8
DewayneH
Sergio,
You had suggested this method on another post and I tried it when I first created the rule.
It worked great to filter out the read-only files, but on save of new files it throws an error.
"The path is not of a legal form."
I guess the rule is calling file path info that doesn't exist yet.
Dewayne
Inventor Pro 2023
Vault Pro 2023
Message 5 of 8
Curtis_Waguespack
Hi @DewayneH
Here is a version of @Sergio.D.Suárez 's example that checks if the file has not name first.
Also I split up the iProperties into 2 different try/catch statements, this is a bit safer and guards against the issue where the first property exists and the other doesn't, in which case the combined try/catch can still error out.
I hope this helps.
Curtis
If doc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Or _
	If doc.FullFileName = "" Then
		oReadOnly = False 'set flag for files with no name
	Else
		oReadOnly = fi.IsReadOnly 'set flag based on file read only
	If oReadOnly = False Then
		Try
		Catch
		End Try
		Try
		Catch
		End Try
Message 6 of 8
DewayneH
Checking the file for a name fixed the error.
The read-only files are skipped as originally requested also.
Initially, I did have an issue with the properties not writing to assembly files.
I realized there was an "<>" instead of an "=" in the code for the document type.
Once fixed, it works perfect.
Thanks to all for the input.
Dewayne
Inventor Pro 2023
Vault Pro 2023
Message 7 of 8
Curtis_Waguespack
oops! 😕
Sorry about that... I started to change that bit to say "if document type is not equal to drawingobject ... but then changed my mind, but apparently left the <> in there... my apologies for the confusion.
If doc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
Message 8 of 8
DewayneH
Curtis,
The code you help me with has worked flawlessly for a few years now.
Recently, I began to notice an occasional error popup with the rule.
"Error on line 37 in rule: Manuf-Commer-Spare, in document:
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))"
The code is below and line 37 is red.
This is only happening with factory files. We don't use them very often which explains why it hasn't been an issue till recently.
I'm currently working with a large batch of iassemblies and am getting it quite frequently.
The rule is set to run before save.
The properties are created initially in the factory as expected with no errors and no errors happen if save is clicked manually.
I've also added the property values in the table for all the members.
The error only occurs when changing members. If a save is required, the error displays before the save dialogue displays.
Any idea how to prevent the error?
Here is the final code you help me with:
'[Rule creates the component classification properties, "Component Class" & "Spare Part" in parts and assemblies.
'Checks if the properties exists, then creates and applies the default value if it doesn't.
'Component Class - Default in parts and assemblies is set according to the files BOM Structure.
'Spare Part - Default is set to "No".
'[Check if document is not drawing.
	'Check if file has file name (for new unsaved files)
	Else
		Try
		Catch
		End Try
		Try
		Catch
		End Try
		'Set "Component Class" according to Documents BOMStructure
		Dim BOMStructure = doc.ComponentDefinition.BOMStructure
		Select Case BOMStructure
			Case = 51974'Inseparable
			Case = 51970'Normal
			Case = 51971'Phantom
				iProperties.Value("Custom", "Component Class") = "PHANTOM"
			Case = 51973'Purchased
				iProperties.Value("Custom", "Component Class") = "COMMERCIAL"
			Case = 51972'Reference
				iProperties.Value("Custom", "Component Class") = "REFERENCE"
		End Select
Dewayne
Inventor Pro 2023
Vault Pro 2023
