SketchEntity Visibility Hide/Unhide
Inventor30Dev
Inventor30Dev
I was not able to hide SketchEntities within a PartDocument.
There is no "Visibile" Property.
If i unterstood correctly the SketchEntity has a Layer property which has a Visibility property, as in: SketchEntity.Layer.Visible
but I was not able to assign any Layer since i didn't find a way to get access to Layers within a PartDocument.
DrawingDocument on the other hand has a StylesManager which has 100 different Layers to chose from. I have even tried to take the Layers from there and assign it to SketchEntity.Layer which gave an exception.
At the moment a workaround is used where the data from the SketchEntity is saved and the SketchEntity Deleted and Recreated when needed. But constrains will then be lost.
Any suggestions?
C_Haines_ENG
If you are just trying to change the visibility of a sketch in a part document, there is no "Layer" property.
Dim oDoc As PartDocument = ThisDoc.Document
For Each oSketch As PlanarSketch In oDoc.ComponentDefinition.Sketches
	oSketch.Visible = False
Next
tim11_manhhieu
Try this, hide and unhide in 1 button
Option Explicit
Sub ShowHideSketches()
If countSketchShow = 1 Then
    Call HideSketches
Else: Call ShowSketches
End Sub
Sub ShowSketches()
Dim doc As PartDocument
Set doc = ThisApplication.ActiveDocument
Dim oSketch As PlanarSketch
For Each oSketch In doc.ComponentDefinition.Sketches
        oSketch.Visible = True
Next
End Sub
Sub HideSketches()
Next
End Sub
Function countSketchShow() As Integer
Dim count As Integer
        If oSketch.Visible = True Then
            count = count + 1
            Exit For
Next
countSketchShow = count
End Function
Inventor30Dev
Thank you for the responses.
But I need to be able to hide a single SketchEntity within a Sketch,
not all the SketchEntities like in both code examples above.
Is there any solution for that?
C_Haines_ENG
Are you talking about hiding a line WITHIN a sketch? That's not possible, and should not be apart of any workflow.
