Sketched Symbol with Sheet number
On a multi page drawing, I want a sketched symbol to placed on a upper right hand side,  “For BOM, see Sheet: X” to be placed on every sheet except the sheet where the parts list available on the drawings. Also the Sketched symbol promped entry automatically filled up with the sheet number (Partslist page). Please hele me on this.
You could make a custom iProperty in the drawing file and read this property with the sketched symbol. This way you only need to set the iProperty with the sheet number containing the partslist once. All sheets will then update with the correct sheet number.
Daniël
Thanks Daniel for your reply. but to know if there any way, This is the existing VBA code what I have,
On Error GoTo ErrHandler
Set oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("For BOM See Sheet: ")
Set osheet = oDrawDoc.ActiveSheet
' This sketched symbol definition contains one prompted string input. An array
' must be input that contains the strings for the prompted strings.
Dim sPromptStrings(0) As String
sPromptStrings(0) = "1"
Dim oTG As TransientGeometry
Set oTG = thisapplication.TransientGeometry
For Each osheet In oDrawDoc.Sheets
osheet.Activate
If osheet.Name <> "Sheet:1" Then
Dim oSketchedSymbol As SketchedSymbol
Set oSketchedSymbol = osheet.SketchedSymbols.Add(oSketchedSymbolDef, oTG.CreatePoint2d(81.7, 52.7), (0), 1, sPromptStrings)
oSketchedSymbol.Static = True
Next
What exactly is your problem with this code?
Current code actually puts (It assumes Partslist is on the first sheet), so it updates the remaining sheets with the sketched symbol, Now the code to be modified by placing the sketched symbol on all sheets, except the sheet if the parts list sheet. (If the partslist present on sheet2, this sketched symbol should not be inserted into this sheet. But the same to be inserted in all the sheets)
You could use someting like this:
Dim sBOMSheet as string
Dim oSh as SHeet
For each oSh in Activedocument.Sheets
  if Not oSh.partslists.count =0 then
      sBOMSheet = oSh.name
      exit for
  end if
next oSh
I haven't tested it, just typed it in this message (so there could be typos in it). With this code you can find the sheet which contains the partslist. Hope you get the idea.
Daniël
Thanks Daniel, this code works
