SketchDrivenPattern - Create new bodies
jiri.paur
jiri.paur
Hello!
I am not able to find out how to set "Create new bodies" for a sketch driven patter via API.
I have tried the following without success:
    'add solid to collection
    Dim colSolid, As ObjectCollection
    Set colSolid, = ThisApplication.TransientObjects.CreateObjectCollection
    colSolid,.Add oShell.SurfaceBodies.Item(1)
    'sketch pattern
    Dim oPtnDef As SketchDrivenPatternDefinition
    Set oPtnDef = oPartDef.Features.SketchDrivenPatternFeatures.CreateDefinition(colSolid, oSketch)
    oPtnDef.Operation = kNewBodyOperation
    Dim oPtn As SketchDrivenPatternFeature
    Set oPtn = oPartDef.Features.SketchDrivenPatternFeatures.Add(oPtnDef)
Any suggestion where I do mistake?
Thank you!
Best regards
Jiri
Michael.Navara
I'm not sure this is bug or feature, but you can set the operation of existing pattern and the result is as expected
Dim part As PartDocument = ThisDoc.Document
Dim partDef As PartComponentDefinition = part.ComponentDefinition
Dim positionSketch As Sketch = partDef.Sketches(2)
Dim parentFeatures As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
parentFeatures.Add(partDef.SurfaceBodies(1))
Dim patternDef As SketchDrivenPatternDefinition = partDef.Features.SketchDrivenPatternFeatures.CreateDefinition(parentFeatures, positionSketch)
patternDef.Operation = PartFeatureOperationEnum.kNewBodyOperation
Dim patternFeature As SketchDrivenPatternFeature = partDef.Features.SketchDrivenPatternFeatures.Add(patternDef)
patternFeature.Definition.Operation = PartFeatureOperationEnum.kNewBodyOperation
jiri.paur
Thank you Michael!
I did not try to set the operation again after the pattern is created. But it works!
Jiri
