Sketch Symbol Placement via iLogic
Jason.Rugg
Jason.Rugg
I have the following code that places a symbol onto drawings, this code is within a larger code that does other things as well. Currently the symbol is placed off of 0,0 but because we use different templates this placement doesn't work for all drawings. Is there a way to detect the bottom right hand corner of the sheet and place the symbol a set distance off of that corner?
Sub PlaceStamp
	' reference to the sketched symbol definition.
	Dim oSymbolDef As SketchedSymbolDefinition
	oSymbolDef = ThisDrawing.Document.SketchedSymbolDefinitions.Item("Drawing Release Stamp")
	Dim oSheet As Sheet = ThisDrawing.Document.ActiveSheet
	'create insertion point, coordinates - in cm !
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oPoint As Point2d = oTG.CreatePoint2d(0, 0)
	' Add an instance of the sketched symbol definition to the sheet.
	' Rotate angle = 0 radians,  scale = 1 when adding
	Dim sPromptStrings(4) As String
	'get prompt values, this example just uses hardcoded values
	sPromptStrings(0) = InputBox("Enter Signature", "iLogic", "")
	sPromptStrings(1) = InputBox("Enter Date", "iLogic", "")
	sPromptStrings(2) = InputBox("Enter Job #", "iLogic", "")
	sPromptStrings(3) = InputBox("Enter Rev", "iLogic", "")
	sPromptStrings(4) = InputBox("If this is a revised drawing, type 'REVISED DRAWING'", "iLogic", "")
	Dim oSymbol As SketchedSymbol
	oSymbol = oSheet.SketchedSymbols.Add(oSymbolDef, oPoint, 0, 1, sPromptStrings)
End Sub
A.Acheson
You can detect the sheet border and retrieve a point from there. This help sample for partslist does a similar thing.
Here is the property for Border.Rangebox in the help file
Dim oBorder As Border = oSheet.Border
Dim PointX as Double = oBorder.RangeBox.MinPoint.X
Dim PointY as Double = oBorder.RangeBox.MinPoint.Y
Regards
Alan
