Hi Guys, I'm working on some automation tool for QC Inspection, basically it's purpose was place a symbol with counter to all dimensions and extract these dimensions to table. Now i complete the first step which is place a symbol on dimensions and i struggle with table creation. please anyone guide me to sort this out
Sub Main() Dim oDoc As DrawingDocument = ThisDoc.Document Dim oSymDef As SketchedSymbolDefinition Try oSymDef = oDoc.SketchedSymbolDefinitions.Item("Your Sketched Symbol Name") Catch ex As Exception MsgBox("Sketch Symbol not found: " & ex.Message) Exit Sub End Try Dim counter As Integer = 1 Dim offsetX As Double = 0.5 Dim offsetY As Double = 0.2 Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim oSheet As Sheet For Each oSheet In oDoc.Sheets Dim oDims As GeneralDimensions = oSheet.DrawingDimensions.GeneralDimensions For Each oDim As GeneralDimension In oDims Dim dimPt As Point2d = oDim.Text.Origin Dim symPt As Point2d = oTG.CreatePoint2d(dimPt.X + offsetX, dimPt.Y + offsetY) Dim oLeaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection() oLeaderPoints.Add(symPt) oLeaderPoints.Add(dimPt) Dim promptValues(0) As String promptValues(0) = counter.ToString() Try Dim oSketchedSymbol As SketchedSymbol = oSheet.SketchedSymbols.AddWithLeader(oSymDef, oLeaderPoints, 0, 1, promptValues) oSketchedSymbol.Static = True oSketchedSymbol.LeaderVisible = False Catch ex As Exception MsgBox("Error placing symbol " & counter & ": " & ex.Message) End Try counter += 1 Next Next End Sub
