Sketch - Project Flat Pattern API
Hello everyone,
I'm trying to write a code snippet to perform "Project Flat Pattern" for a selected edge. I tried some different approaches but failed all.
// inputs
var oEdge = _InventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartEdgeLinearFilter, "Select an edge") as Inventor.Edge;
var oSketch = _InventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kSketchObjectFilter, "Select a sketch to do projection") as Inventor.PlanarSketch;
// result
var sheetMetalComp = (_InventorApp.ActiveDocument as PartDocument).ComponentDefinition as SheetMetalComponentDefinition; var flatEdge = sheetMetalComp.FlatPattern.GetFlatPatternEntity(oEdge); oSketch.AddByProjectingEntity(flatEdge);
Your help will be much appreciated!
(*) I'm using C# but if you're familiar with VBA or VB.NET, it's okay for me. I can understand. 🙂
Sergio.D.Suárez
Hi, have you tried with the preset commands?
I'm not sure if they would work in your programming environment, which I share below is an example of VBA. On the other hand, remember that this command projects Faces no edges.
Sub ProjectFlat()
    Dim oCommand As CommandManager
    Set oCommand = ThisApplication.CommandManager
    Dim oControlDef As ControlDefinition ' Get control definition for the line command.
    Set oControlDef = oCommand.ControlDefinitions.Item("SketchProjectFlatPatternCmd")
    oControlDef.Execute2 (True) ' Execute the command.
End Sub
I hope this can help you with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank you @Sergio.D.Suárez .
However, it seems my post wasn't well-described. Let me explain a little bit.
Pretend I already had:
  • A sketch set to variable oSketch.
  • A bend (face) set to variable oBend.
I want oSketch to perform "Project Flat Pattern" the oBend to it. The results are the green lines as shown below.
2019-10-28_19-35-56.pngHopefully now my question is clear. 😅
MateriaGris
Hi everyone.
I am interested in knowing if it is possible to do what Anonymous asks
I want to project flat pattern onto a sketch and place a point at the end of each bend edge, but I can't find a way to do it automatically from within iLogic.
I am attaching an example file showing what I am interested in doing.
I really appreciate if you can help me.
SevInventor
Hello Anonymous 199,
found out how to project the Flat pattern edges and bend lines and bring the sketch intend to the folded model.
Got some code of a similar topic from here:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/sketch-on-flat-pattern-issue/td-p/71...
Only the orientation and position of the sketch in the folded model is wrong:
I'm sure this task can be solved as well. Pleas feel free to further develop this code
Sub Main
'[ edit these variables as needed
sSketchName = "Flat Pattern Sketch"
'  a reference to the active document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
'verify document type is sheet metal
If oPartDoc.ComponentDefinition.Type <> 150995200 Then
	MessageBox.Show("File is not a sheet metal part.", "iLogic")
	Exit Sub
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
' Check to make sure a flat pattern is open.
If Not TypeOf ThisApplication.ActiveEditObject Is FlatPattern Then
	Try
		If oCompDef.HasFlatPattern = False Then
			oCompDef.Unfold
		Else
			oCompDef.FlatPattern.Edit
	Catch
		MessageBox.Show("Error editting the flat pattern.", "iLogic")
	End Try
'  a reference to the active flat pattern.
Dim oFlatPattern As FlatPattern
oFlatPattern = ThisApplication.ActiveEditObject
Dim oFace As Face
oFace = oFlatPattern.TopFace
Dim oSketch As PlanarSketch
'clean up existing sketch
For Each oSketch In oFlatPattern.Sketches
	If oSketch.Name = sSketchName Then
		oSketch.Delete
Next
' Create a new sketch.
' the Second argument specifies To include/Not include
' the edges of the face in the sketch.
oSketch = oFlatPattern.Sketches.Add(oFace, False)
' Change the name.
Dim oEdges As Edges
	UpEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
	For Each Upedge In UpEdges
		Dim line As SketchLine = oSketch.AddByProjectingEntity(Upedge)
	Next
	DownEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
	For Each DownEdge In DownEdges
		Dim line As SketchLine = oSketch.AddByProjectingEntity(DownEdges)
	Next
	For Each oEdge In oFlatPattern.TopFace.Edges
		Call oSketch.AddByProjectingEntity(oEdge)
	Next
oCompDef.FlatPattern.ExitEdit
Dim oFace2 As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select Surface to add flat sketch")
Dim oSketch2 As PlanarSketch
oSketch2 = oCompDef.Sketches.Add(oFace2,True)
oSketch.CopyContentsTo(oSketch2)
oPartDoc.Save
End Sub
