Sketch orientation - align with selected face
NachoShaw
Advisor Advisor
Message 1 of 15
NachoShaw
Hey
Im adding a sketch by doing the following-
select edge
add plane (normal to edge)
add workpoint
add sketch to plane on workpoint
add sketch lines to sketch at defined size (.75 x .25)
add constraints to sketch lines
problem im having is the orientation of the sketch. sometimes it correct, sometimes its not. I think id like to select a defining face first to set the direction of the sketch but im struggling to do that.
in the picture above, sketch (A) is how i need to be every time. Id like to select a face, align the sketch as shown and then it always orients this direction. Sketch (B) is rotated 90 degrees but needs to align with the selected face.
The pink lines i added to show the edges that i selected.
Is there a way to orient a sketch based on a selected face? here is my code:
Sub Rebate()
Dim oApp As Inventor.Application: Set oApp = ThisApplication
Dim oPartDoc As PartDocument: Set oPartDoc = oApp.ActiveDocument
Dim oCompDef As PartComponentDefinition: Set oCompDef = oPartDoc.ComponentDefinition
Dim oTG As TransientGeometry: Set oTG = oApp.TransientGeometry
Dim oFace As Face: Set oFace = oApp.CommandManager.Pick(kAllPlanarEntities, "pick rebate face")
Dim oEdge As Edge: Set oEdge = oApp.CommandManager.Pick(kPartEdgeFilter, "pick edge")
'Try to find the selected edge in the face edge collection
'if found, set the edge as the face edge
Dim e As Edge
For Each e In oFace.Edges
    If e.TransientKey = oEdge.TransientKey Then
        Set oEdge = e
Next
' Get the start vertex of the edge to use as the origin of the sketch.
Dim oVertex As Vertex
Set oVertex = oEdge.StartVertex
Dim oPT As WorkPoint: Set oPT = oCompDef.WorkPoints.AddByMidPoint(oEdge)
oPT.Visible = False
Dim oWP As WorkPlane: Set oWP = oCompDef.WorkPlanes.AddByNormalToCurve(oEdge, oPT)
oWP.Visible = False
''create the sketch
'Dim oSketch As PlanarSketch: Set oSketch = oCompDef.Sketches.Add(oWP)
Set oSketch = oCompDef.Sketches.AddWithOrientation(oWP, oEdge, True, True, oEdge.StartVertex, True)
'Set oSketch = oCompDef.Sketches.AddWithOrientation(oWP, oEdge, False, False, oVertex, False)
'project the edge to create a point
Dim p As SketchPoint
Set p = oSketch.AddByProjectingEntity(oEdge)
'create the rectangle at the projected point
Dim r As SketchEntitiesEnumerator
Set r = oSketch.SketchLines.AddAsTwoPointCenteredRectangle(p, oTG.CreatePoint2d(0.25, 0.125))
Dim oSketchLine As SketchLine
Set oSketchLine = r.Item(1)
Call oSketch.DimensionConstraints.AddTwoPointDistance(oSketchLine.StartSketchPoint, oSketchLine.EndSketchPoint, kHorizontalDim, oTG.CreatePoint2d(0, -2))
Set oSketchLine = r.Item(4)
Call oSketch.DimensionConstraints.AddTwoPointDistance(oSketchLine.StartSketchPoint, oSketchLine.EndSketchPoint, kVerticalDim, oTG.CreatePoint2d(-2, 0))
oSketch.AxisEntity = oCompDef.WorkAxes.Item(2)
oSketch.OriginPoint = oPT
Dim oConstraint1 As TwoPointDistanceDimConstraint
Set oConstraint1 = oSketch.DimensionConstraints.Item(1)
oConstraint1.Parameter.Expression = "Depth"
Dim oConstraint2 As TwoPointDistanceDimConstraint
Set oConstraint2 = oSketch.DimensionConstraints.Item(2)
oConstraint2.Parameter.Expression = "Rebate"
Dim oSketch3D As Sketch3D
Set oSketch3D = oCompDef.Sketches3D.Add
Dim oLine As SketchLine3D
Set oLine = oSketch3D.Include(oEdge)
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
Dim oPath As Path
Set oPath = oCompDef.Features.CreatePath(oLine)
Dim spDef As SweepDefinition
Set spDef = oCompDef.Features.SweepFeatures.CreateSweepDefinition(kPathSweepType, oProfile, oPath, kCutOperation)
Dim sp As SweepFeature
Set sp = oCompDef.Features.SweepFeatures.Add(spDef)
End Sub
thanks for any help
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Replies (14)
Message 2 of 15
WCrihfield
Just at thought, but since your sketch isn't 'on' the selected face, and it's mainly for orientation, maybe selecting another Edge that is perpendicular to the other selected edge, would work better for orientation purposes.  Maybe you could extract a UnitVector (direction) from the first Edge, then use it to ensure the orientation (direction) of the sketch geometry.  Then the second edge is still setting the height of the sketch plane and ensures the sketch plane is perpendicular to the second selected edge, as it currently seems.
Also, just a tip, but when checking the edges against each other, you could simply check If e Is oEdge.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 15
NachoShaw
Hi
Thanks for the reply. I originally did a If e = oEdge and did a test
dim e As Edge
For Each e in oFace.Edges
   If e = oEdge Then
      MsgBox("Found Edge")
Next
but i got a message flash for every edge so i didnt have much confidence it that approach..
Using a selected Edge would be ok, it wouldnt typically fit with the process though as the assumption would be to select a face to have the rebate cut into. maybe i could loop through the face edges to find one that works..
Thanks 🙂
Nacho
Message 4 of 15
NachoShaw
or something else that could work- select the rebate face and the then the edge to find the intersecting edge. From a workflow standpoint, selecting faces would be better than edges as long as the cut profile can be correctly oriented
Nacho
Message 5 of 15
NachoShaw
so i ran a bit of code to show me the UCS of each edge and i can see there is a difference which would help me set a direction. in this image, the left edge cut has the sketch aligned with the Y axis, the right sketch is aligned with the Z axis. If i could access the axis of the edge, i can change the sketch dimension constraints to align. For example:
get sketch longest edge
if it doesnt align with the Y axis, change the dimension constraints to switch values
Nacho
Message 6 of 15
Stakin
without image
Message 7 of 15
NachoShaw
oops
Here is the image as referenced
Furthermore, here is an image of the same edge between 2 faces with 2 UCS which leads me to think there are 2 edges, 1 for each face
In the meantime, i managed to figure out a way to determine the direction albeit i dont think its the method i am looking for. By looking at the Normal of each edge, there was a pattern difference between the ones that worked and the ones that didnt. I cased the pattern and changed the orientation of the dims which resolved my issue. Id like to think there is a better way to do this like compare the Y axis or check for a parallel but for now, this is working..
Cheers
Nacho
Message 8 of 15
Stakin
Dim oSketch As PlanarSketch Set oSketch = oCompDef.Sketches.AddWithOrientation(oWP, oEdge, True, True, oEdge.StartVertex, True)
the SketchOrientation is not a 3D Direction,
oEdge is perpendicular to the sketch plane,it cann't be sketch X、Y direction。
For this instance,you can use the vector which is cross product of the selceted edge's  Normal and the Selected face' normal.
And the origin,you should use the midpoint of the oedge
Message 9 of 15
Stakin
on the sketchplane ,it‘s UCS just two direction,and just assign one Xdirection for it,the other Ydirection will determine with Xdirection and the sketchplane’s Nomal by Right hand rule。
Message 10 of 15
NachoShaw
thanks for that. The -
was me testing if thats what i needed but i suspected it wasnt. I have reverted back to
Set oSketch = oCompDef.Sketches.Add(oWP, False)
Nacho
Message 11 of 15
WCrihfield
Hi @NachoShaw.  Sorry for the delay...I've been away a few days.  And now that I'm back, things at work have gotten busy.
In my earlier post about checking the edge variables, I didn't say to check it like "If e = oEdge", I said it would likely be easier to check it like "If e Is oEdge", using the operator "Is", instead of equals (=).  When comparing some objects (not information data variables), it is sometimes easiest/best to use "Is" when comparing, rather than =, that's all.  Sorry for the confusion.
Wesley Crihfield
Message 12 of 15
NachoShaw
Hey
No worries mate. Makes sense to Is instead of =. Im thinking of a different approach now as the current method seems a little problematic 🙂
Im going to look at using SurfaceGraphics to give me a feature preview and process the feature after the selection is complete. The method i was using added the feature per edge and previewed it with a Transaction but that was becoming too complicated for what it was. 🙂
Nacho
Message 13 of 15
Stakin
PlanarSketches.AddWithOrientation( PlanarEntity As Object, AxisEntity As Object, NaturalAxisDirection As Boolean, AxisIsX As Boolean, Origin As Object, [UseFaceEdges] As Boolean )
you can try it agian, AxisEntity Use the below UnitVector -----  oXvector(it aline with the face direction)
                                    Origin        Use the oEdge.MidPoint
dim oXvector As UnitVector
Dim oLineSeg As LineSegment
oLineSeg = oEdge.Geometry
Dim eval As SurfaceEvaluator
    eval = oFace.Evaluator
    Dim center(1) As Double
    center(0) = (eval.ParamRangeRect.MinPoint.X + eval.ParamRangeRect.MaxPoint.X) / 2
    center(1) = (eval.ParamRangeRect.MinPoint.y + eval.ParamRangeRect.MaxPoint.y) / 2
    Dim normal() As Double
    Call eval.GetNormal(center, normal)
    GetFaceNormal = ThisApplication.TransientGeometry.CreateUnitVector(normal(0), normal(1), normal(2))
oXvector= oLineSeg.Direction.CrossProduct( GetFaceNormal)
Message 14 of 15
NachoShaw
much appreciated for you reply. I tried the code but couldnt get it work It kept giving me an error on the CreateSketchWithOrientation - Invalid procedure call or argument
Set oSketch = oCompDef.Sketches.AddWithOrientation(oWP, oXvector, True, True, oLineSeg.MidPoint)
oEdge doesnt have MidPoint
Nacho
Message 15 of 15
Stakin
Dim oWkAxes As WorkAxes
Set oWkAxes=oCompDef.WorkAxes.AddFixed(oLineSeg.MidPoint,oXvector,1)
Set oSketch = oCompDef.Sketches.AddWithOrientation(oWP, oWkAxes, True, True, oLineSeg.MidPoint)
