Sketch / Open loop / Redundant Points
m_baczewski
m_baczewski
My problem is that when I add a sketch to the drawing, each line in the sketch is separate, and I can't use the "Hatch the region" operation. I can only achieve this after using the sketch doctor and removing excess points. How can I add such a sketch without creating too many excessive points? Each of these lines is a separate object. How can I connect them together?
I adding sketch like that:
oSketch.SketchLines.AddByTwoPoints(pointA, pointB)
oSketch.SketchLines.AddByTwoPoints(pointB,pointC)
oSketch.SketchLines.AddByTwoPoints(pointC,pointD)
oSketch.SketchLines.AddByTwoPoints(pointD,pointE)
oSketch.SketchLines.AddByTwoPoints(pointE,pointF)
oSketch.SketchLines.AddByTwoPoints(pointF, pointA)
Michael.Navara
It is not clear from your sample, but I expect the variables pointX are of type Point2D. SketchLines.AddByTwoPoints Method accepts Point2D or SketchPoint objects as arguments. Use SketchPoints instead and it will work.
Michael.Navara
Sample with generic function for creation of closed lines loop
Sub Main()
    'Sketch drawing must be active
    Dim sketch As DrawingSketch = ThisApplication.ActiveEditObject
    Dim linesCollection = CreateClosedPolyLine(sketch,
        ThisApplication.TransientGeometry.CreatePoint2d(0, 0),
        ThisApplication.TransientGeometry.CreatePoint2d(0, 1),
        ThisApplication.TransientGeometry.CreatePoint2d(1, 1),
        ThisApplication.TransientGeometry.CreatePoint2d(1, 2),
        ThisApplication.TransientGeometry.CreatePoint2d(2, 2),
        ThisApplication.TransientGeometry.CreatePoint2d(2, 0)
    Dim profile As Profile = sketch.Profiles.AddForSolid(True, linesCollection)
    sketch.SketchHatchRegions.Add(profile)
End Sub
Function CreateClosedPolyLine(sketch As Sketch, ParamArray points() As Point2d) As ObjectCollection
    If points.Length < 3 Then Throw New ArgumentException("At least three points must be provided")
    Dim lines As ObjectCollection = sketch.Application.transientObjects.CreateObjectCollection()
    Dim line As SketchLine = sketch.SketchLines.AddByTwoPoints(points(0), points(1))
    lines.Add(line)
    Dim startPoint As SketchPoint = line.EndSketchPoint
    Dim lastPoint As SketchPoint = line.StartSketchPoint
    For i As Integer = 2 To points.Length - 1
        line = sketch.SketchLines.AddByTwoPoints(startPoint, points(i))
        lines.Add(line)
        startPoint = line.EndSketchPoint
    Next
    line = sketch.SketchLines.AddByTwoPoints(startPoint, lastPoint)
    lines.Add(line)
    Return lines
End Function
m_baczewski
Its working very well. Thanks a lot!
