Sketch line functionality through VBA
I was wondering if anyone may have some insight as to how to accomplish something I'm having an issue with.  I am trying to create a line function for a specific work task.  What I want to do is create a line through user interaction, similar to how the line command works within Inventor.  I then want to offset a construction line to each side and dimension them.  This is to simulate the different size tubing that will be used as the skeleton for Frame Generator.
I found a bit of code for using MouseEvents, which works wonderfully, but doesn't have any kind of snaps, which I need.  I would like to keep horizontal and vertical snapping for the second point in relation to the first, but also allow for coincident constraints when clicking on an existing element.
Any help or suggestion on a good direction to go is much appreciated.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Try below VBA code to calculate second point based on orientation (Horizontal or vertical). This code is embedded with MouseEvents. For more details on MouseEvents, refer below link.
https://forums.autodesk.com/t5/inventor-customization/selecting-a-point2d-with-your-mouse-on-a-drawing-sheet/td-p/3739407
Public Sub TestGetDrawingPoint()
    Dim getPoint As New clsGetPoint
    Dim pnt1 As Point2d
    Dim pnt2 As Point2d
    Do
        Set pnt1 = getPoint.GetDrawingPoint("Click the desired location", kLeftMouseButton)
        If Not pnt1 Is Nothing Then
            Dim lineLen As Double
            lineLen = InputBox("Enter the length of line")
            Dim line_orientation As String
            line_orientation = InputBox("Type H(Horizontal) or V(Vertical)")
            line_orientation = UCase(line_orientation)
            Dim hor_Alignment As String
            Dim ver_Alignment As String
            If line_orientation = "H" Then
               hor_Alignment = InputBox("Type L(Left) or R(Right)")
               hor_Alignment = UCase(hor_Alignment)
               If hor_Alignment = "L" Then
                    Set pnt2 = ThisApplication.TransientGeometry.CreatePoint2d(pnt1.X - lineLen, pnt1.Y)
               ElseIf hor_Alignment = "R" Then
                    Set pnt2 = ThisApplication.TransientGeometry.CreatePoint2d(pnt1.X + lineLen, pnt1.Y)
               Else
                    MsgBox ("Invalid entry for horizantal alignment")
            ElseIf line_orientation = "V" Then
                ver_Alignment = InputBox("Type U(Upward) or D(Downward)")
                ver_Alignment = UCase(ver_Alignment)
                If ver_Alignment = "U" Then
                    Set pnt2 = ThisApplication.TransientGeometry.CreatePoint2d(pnt1.X, pnt1.Y + lineLen)
                ElseIf ver_Alignment = "D" Then
                    Set pnt2 = ThisApplication.TransientGeometry.CreatePoint2d(pnt1.X, pnt1.Y - line_len)
                Else
                    MsgBox ("Invalid entry for vertical alignment")
            Else
                MsgBox ("Invalid Entry for line orientation")
    Loop While Not pnt Is Nothing
End Sub
Need to create a Class module called "clsGetPoint" and include the below code.
Private WithEvents m_interaction As InteractionEvents
Private WithEvents m_mouse As MouseEvents
Private m_position As Point2d
Private m_button As MouseButtonEnum
Private m_continue As Boolean
Public Function GetDrawingPoint(Prompt As String, button As MouseButtonEnum) As Point2d
    Set m_position = Nothing
    m_button = button
    Set m_interaction = ThisApplication.CommandManager.CreateInteractionEvents
    Set m_mouse = m_interaction.MouseEvents
    m_interaction.StatusBarText = Prompt
    m_interaction.Start
    m_continue = True
    Do
        DoEvents
    Loop While m_continue
    m_interaction.Stop
    Set GetDrawingPoint = m_position
End Function
Private Sub m_mouse_OnMouseClick(ByVal button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
    If button = m_button Then
        Set m_position = ThisApplication.TransientGeometry.CreatePoint2d(ModelPosition.X, ModelPosition.Y)
    m_continue = False
End Sub
For coincident constraint, refer the suggestions in below links.
https://forums.autodesk.com/t5/inventor-customization/addcoincident-constraint-for-multiple-sketch-entities/td-p/4634085
http://adndevblog.typepad.com/manufacturing/2012/05/addcoincident-with-two-sketch-points.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Awesome, thank you for the quick response.  It is a bit less user friendly than I was hoping though as I am looking for more the program behavior, ie. automatically snapping if within a certain tolerance of the first point.
I was playing with adding in an if statement for each axis, along the lines of (my computer crashed yesterday, so I don't have the exact code, but it was taking a start and end point that were user selected in space):
If Abs(ModelPosition.X - StartPoint.X) <= 10 Then
    ModelPosition.X = StartPoint.X
It worked at certain times with a single axis, but adding 3 axes made it not work. It also wasn't unlatching from the first created line.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @Anonymous,
Can you please elaborate on above statement?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
@chandra.shekar.g
Sure, sorry I had just pulled up my chair at work.  My statement is in regard to code unrelated to what you posted.  It is posted below.
What I mean is that the code I have worked when I had only a single axis defined with the statement I wrote in my previous post.  Once I created one line, however, the reference to that line remained, affecting what all lines afterwards saw as the reference for the statement (that's what I mean by it didn't unlatch).
Public Sub DrawSketchLine()
    ' Check to make sure a sketch is active.
    If Not TypeOf ThisApplication.ActiveEditObject Is sketch Then
        MsgBox "A sketch must be active."
        Exit Sub
    Set oClass1 = New Class1
    oClass1.Initialize
End Sub
Option Explicit
Private WithEvents oInteractionEvents As InteractionEvents
Private WithEvents oMouseEvents As MouseEvents
Private oIntGraphics As InteractionGraphics
Private oStartPoint As Point
Private oEndPoint As Point
Public Sub Initialize()
    Set oStartPoint = Nothing
    Set oEndPoint = Nothing
    Set oInteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents
    Set oMouseEvents = oInteractionEvents.MouseEvents
    oMouseEvents.MouseMoveEnabled = True
    oMouseEvents.PointInferenceEnabled = True
    Set oIntGraphics = oInteractionEvents.InteractionGraphics
    oInteractionEvents.Start
End Sub
Private Sub oMouseEvents_OnMouseDown(ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
    If oStartPoint Is Nothing Then
        Set oStartPoint = ModelPosition
    Else
    '\\\\\\ HERE! \\\\\\
        If Abs(ModelPosition.X - oStartPoint.X) <= 10 Then
            ModelPosition.X = oStartPoint.X
            ElseIf Abs(ModelPosition.Y - oStartPoint.Y) <= 10 Then
            ModelPosition.Y = oStartPoint.Y
            ElseIf Abs(ModelPosition.Z - oStartPoint.Z) <= 10 Then
            ModelPosition.Z = oStartPoint.Z
        Set oEndPoint = ModelPosition
        Dim oSketchLine As SketchLine
        Dim oStartPoint2d As Point2d
        Dim oEndPoint2d As Point2d
        If TypeOf ThisApplication.ActiveEditObject Is PlanarSketch Then
            Dim oSketch2d As PlanarSketch
            Set oSketch2d = ThisApplication.ActiveEditObject
            Set oStartPoint2d = oSketch2d.ModelToSketchSpace(oStartPoint)
            Set oEndPoint2d = oSketch2d.ModelToSketchSpace(oEndPoint)
            Set oSketchLine = oSketch2d.SketchLines.AddByTwoPoints(oStartPoint2d, oEndPoint2d)
            Dim offsetCol As ObjectCollection
            Set offsetCol = ThisApplication.TransientObjects.CreateObjectCollection
            offsetCol.Add oSketchLine
            Call oSketch2d.OffsetSketchEntitiesUsingDistance(offsetCol, 2.54, True, False, True)
            Call oSketch2d.OffsetSketchEntitiesUsingDistance(offsetCol, 2.54, False, False, True)
        ElseIf TypeOf ThisApplication.ActiveEditObject Is DrawingSketch Then
            Dim oDrawingSketch As DrawingSketch
            Set oDrawingSketch = ThisApplication.ActiveEditObject
            Set oStartPoint2d = oDrawingSketch.SheetToSketchSpace(ThisApplication.TransientGeometry.CreatePoint2d(oStartPoint.X, oStartPoint.Y))
            Set oEndPoint2d = oDrawingSketch.SheetToSketchSpace(ThisApplication.TransientGeometry.CreatePoint2d(oEndPoint.X, oEndPoint.Y))
            Set oSketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oStartPoint2d, oEndPoint2d)
End Sub
Private Sub oMouseEvents_OnMouseMove(ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
    If Not oStartPoint Is Nothing Then
        ' Set a reference to the transient geometry object for user later.
        Dim oTransGeom As TransientGeometry
        Set oTransGeom = ThisApplication.TransientGeometry
        ' Create a graphics data set object.  This object contains all of the
        ' information used to define the graphics.
        Dim oDataSets As GraphicsDataSets
        Set oDataSets = oIntGraphics.GraphicsDataSets
        If oDataSets.Count <> 0 Then
            oDataSets.Item(1).Delete
        ' Create a coordinate set.
        Dim oCoordSet As GraphicsCoordinateSet
        Set oCoordSet = oDataSets.CreateCoordinateSet(1)
        ' Create an array that contains coordinates
        Dim oPointCoords(5) As Double
        oPointCoords(0) = oStartPoint.X
        oPointCoords(1) = oStartPoint.Y
        oPointCoords(2) = oStartPoint.Z
        oPointCoords(3) = ModelPosition.X
        oPointCoords(4) = ModelPosition.Y
        oPointCoords(5) = ModelPosition.Z
        ' Assign the points into the coordinate set.
        Call oCoordSet.PutCoordinates(oPointCoords)
        'Set preview color to red.
        Dim oColorSet As GraphicsColorSet
        Set oColorSet = oDataSets.CreateColorSet(1)
        oColorSet.Add 1, 0, 255, 0
        ' Create the ClientGraphics object.
        Dim oClientGraphics As ClientGraphics
        Set oClientGraphics = oIntGraphics.PreviewClientGraphics
        If oClientGraphics.Count <> 0 Then
            oClientGraphics.Item(1).Delete
        ' Create a new graphics node within the client graphics objects.
        Dim oLineNode As GraphicsNode
        Set oLineNode = oClientGraphics.AddNode(1)
        ' Create a LineGraphics object within the node.
        Dim oLineSet As LineStripGraphics
        Set oLineSet = oLineNode.AddLineStripGraphics
        oLineSet.ColorSet = oColorSet
        ' Assign the coordinate set to the line graphics.
        oLineSet.CoordinateSet = oCoordSet
        ThisApplication.ActiveView.Update
End Sub
Private Sub oInteractionEvents_OnTerminate()
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
Hello @Anonymous,
Hoping that below angle algorithm would help to draw horizontal and vertical line.
    If Not TypeOf ThisApplication.ActiveEditObject Is Sketch Then
        Exit Sub
    Dim getPoint As New Class1
    Dim pnt As Integer
    pnt = 0
    Do
        Call getPoint.Initialize("Click the desired location", kLeftMouseButton)
        pnt = pnt + 1
    Loop While pnt > 2
End Sub
Public Sub Initialize(Prompt As String, Button As MouseButtonEnum)
    m_button = Button
    oInteractionEvents.StatusBarText = Prompt
    m_continue = True
    Do
    DoEvents
    m_interaction.Stop
End Sub
    Else
        Dim dY As Double
        Dim dX As Double
        Dim m As Double
        dY = oStartPoint.Y - ModelPosition.Y
        dX = oStartPoint.X - ModelPosition.X
        m = dY / dX
        Dim angle As Double
        angle = Atn(m) * 180 / 3.1415
        If Abs(angle) >= 45 Then
'Draws vertical line ModelPosition.X = oStartPoint.X ElseIf Abs(angle) <= 45 Then
'Draws horizontal line ModelPosition.Y = oStartPoint.Y End If Set oEndPoint = ModelPosition Dim oSketchLine As SketchLine Dim oStartPoint2d As Point2d Dim oEndPoint2d As Point2d If TypeOf ThisApplication.ActiveEditObject Is PlanarSketch Then Dim oSketch2d As PlanarSketch Set oSketch2d = ThisApplication.ActiveEditObject Set oStartPoint2d = oSketch2d.ModelToSketchSpace(oStartPoint) Set oEndPoint2d = oSketch2d.ModelToSketchSpace(oEndPoint) Set oSketchLine = oSketch2d.SketchLines.AddByTwoPoints(oStartPoint2d, oEndPoint2d) Dim offsetCol As ObjectCollection Set offsetCol = ThisApplication.TransientObjects.CreateObjectCollection offsetCol.Add oSketchLine Call oSketch2d.OffsetSketchEntitiesUsingDistance(offsetCol, 2.54, True, False, True) Call oSketch2d.OffsetSketchEntitiesUsingDistance(offsetCol, 2.54, False, False, True) ElseIf TypeOf ThisApplication.ActiveEditObject Is DrawingSketch Then Dim oDrawingSketch As DrawingSketch Set oDrawingSketch = ThisApplication.ActiveEditObject Set oStartPoint2d = oDrawingSketch.SheetToSketchSpace(ThisApplication.TransientGeometry.CreatePoint2d(oStartPoint.X, oStartPoint.Y)) Set oEndPoint2d = oDrawingSketch.SheetToSketchSpace(ThisApplication.TransientGeometry.CreatePoint2d(oEndPoint.X, oEndPoint.Y)) Set oSketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oStartPoint2d, oEndPoint2d) End If Set oStartPoint = Nothing Set oEndPoint = Nothing End If End Sub Private Sub oMouseEvents_OnMouseMove(ByVal Button As MouseButtonEnum, ByVal ShiftKeys As ShiftStateEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View) If Not oStartPoint Is Nothing Then ' Set a reference to the transient geometry object for user later. Dim oTransGeom As TransientGeometry Set oTransGeom = ThisApplication.TransientGeometry ' Create a graphics data set object. This object contains all of the ' information used to define the graphics. Dim oDataSets As GraphicsDataSets Set oDataSets = oIntGraphics.GraphicsDataSets If oDataSets.Count <> 0 Then oDataSets.Item(1).Delete End If ' Create a coordinate set. Dim oCoordSet As GraphicsCoordinateSet Set oCoordSet = oDataSets.CreateCoordinateSet(1) ' Create an array that contains coordinates Dim oPointCoords(5) As Double oPointCoords(0) = oStartPoint.X oPointCoords(1) = oStartPoint.Y oPointCoords(2) = oStartPoint.Z oPointCoords(3) = ModelPosition.X oPointCoords(4) = ModelPosition.Y oPointCoords(5) = ModelPosition.Z ' Assign the points into the coordinate set. Call oCoordSet.PutCoordinates(oPointCoords) 'Set preview color to red. Dim oColorSet As GraphicsColorSet Set oColorSet = oDataSets.CreateColorSet(1) oColorSet.Add 1, 0, 255, 0 ' Create the ClientGraphics object. Dim oClientGraphics As ClientGraphics Set oClientGraphics = oIntGraphics.PreviewClientGraphics If oClientGraphics.Count <> 0 Then oClientGraphics.Item(1).Delete End If ' Create a new graphics node within the client graphics objects. Dim oLineNode As GraphicsNode Set oLineNode = oClientGraphics.AddNode(1) ' Create a LineGraphics object within the node. Dim oLineSet As LineStripGraphics Set oLineSet = oLineNode.AddLineStripGraphics oLineSet.ColorSet = oColorSet ' Assign the coordinate set to the line graphics. oLineSet.CoordinateSet = oCoordSet ThisApplication.ActiveView.Update End If End Sub Private Sub oInteractionEvents_OnTerminate() ThisApplication.ActiveView.Update End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
@chandra.shekar.g
Thank you.  It looks like this would work for what I requested.  I ended up going a slightly different (more complicated, so your solution may help when refactoring / recoding to C# as an add-in) route to get to the same result.
I sincerely appreciate you taking the time to help.
