Sketch in a drawing section view
rlileikis
rlileikis
Hello. I am making a drawing of my part. I have base view. I made section view "A-A" too. I need to make a sketch into section view "A-A". I will draw few lines in that sketch.
How i can use iLogic to get into that sketch? I need to assign some parameters to these lines.
A.Acheson
Here is a post to loop through and target views and creating a sketch.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/ilogic-rule-to-create-sketch-on-idw-vie...
Here is a post to select a view and then you can apply that with the first post to work on the sketch.
https://forums.autodesk.com/t5/inventor-ilogic-api-vba-forum/select-a-view-with-ilogic-view/td-p/882...
If you have any questions just put up your attempt of the workflow you would like to use and I am sure someone can help.
Regards
Alan
