Sketch export failed to initialize translator
lerskine24UR7
Message 1 of 1
lerskine24UR7
Got quite a long one here, but I have an addon I have compiled in Visual Studio, and both of the following scripts work great, unless "PrintUpdate" is run before "dxfUpdate".
Here is a link to the GitHub page if you want to test the addon yourself: Release v1.4.6.0 · Bmassner/Doyle-AddIn · GitHub
"PrintUpdate" obviously only runs on .idw
After running "PrintUpdate" and I switch back to a sheet metal part I get the "Sketch export failed to initialize translator" error as well as this in VS:
System.Runtime.InteropServices.COMException
  HResult=0x80004005
  Message=Class not registered
  Source=System.Private.CoreLib
  StackTrace:
   at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Object[] aArgs, Boolean[] aArgsIsByRef, Int32[] aArgsWrapperTypes, Type[] aArgsTypes, Type retType)
   at Inventor.DataIO.WriteDataToFile(String Format, String FileName)
   at Doyle_Addin.dxfUpdate.runDxfUpdate(Application ThisApplication) in C:\Users\Test2\dxfUpdate.vb:line 103
I have to restart inventor to reenable the translator.
Imports Inventor
Module dxfUpdate
    Sub runDxfUpdate(ThisApplication As Inventor.Application)
        Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
        Dim oDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
        Dim oFactory As iPartFactory = oDef.iPartFactory
        Dim oRow As iPartTableRow
        'Check if part is a factory
        If oDef.IsiPartFactory = True Then
            'Go through all rows
            For Each oRow In oFactory.TableRows
                oFactory.DefaultRow = oRow
                Dim partMaterial As String = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Material").Value.ToString
                MsgBox(partMaterial)
                Dim partAppearance As String = oPartDoc.ActiveAppearance.Name.ToString
                MsgBox(partAppearance)
                If oDef.FlatPattern.FlatBendResults.Count = 0 And (oDef.FlatPattern.RangeBox.MaxPoint.Z - oDef.FlatPattern.RangeBox.MinPoint.Z) > (oDef.Thickness.Value + 0.003) Then
                    MsgBox("Invalid")
                Else
                    MsgBox("Valid")
                'Get part number
                Dim PN As String = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value.ToString
                'Set data write output format
                Dim oFormat As String = "FLAT PATTERN DXF?AcadVersion=2018" _
                    + "&BendDownLayer=DOWN&BendDownLayerColor=255;0;0" _
                    + "&BendUpLayer=UP&BendUpLayerColor=255;0;0" _
                    + "&OuterProfileLayer=OUTER&OuterProfileLayerColor=0;0;255" _
                    + "&InteriorProfilesLayer=INNER&InteriorProfilesLayerColor=0;0;0" _
                    + "&ArcCentersLayer=POINT&ArcCentersLayerColor=255;0;255" _
                    + "&TangentLayer=RADIUS&TangentLayerColor=255;255;0"
                'Set output path
                Dim oFileName As String = "X:\" & PN & ".dxf"
                'Make a flat pattern if one doesn't exist and refold
                If oDef.HasFlatPattern = False Then
                    Try
                        oDef.Unfold()
                        oDef.FlatPattern.ExitEdit()
                    Catch ex As Exception
                        MsgBox("Failed to create flat pattern")
                        Return
                    End Try
                'Create dxf
                Try
                    oDef.DataIO.WriteDataToFile(oFormat, oFileName)
                    MsgBox("DXF failed to generate")
                    Return
                End Try
            Next
            'Reset to first member
            oRow = oFactory.TableRows.Item(1)
            Dim Total As Integer = oFactory.TableRows.Count
            MsgBox("Created " & Total)
        Else
            'All same as above, for non-iparts
                oDef.Unfold()
            Try
                MsgBox("Check to see if you are connected to the X Drive and try again")
                Return
            End Try
    End Sub
End Module
Imports Inventor
Module PrintUpdate
    Public Sub RunPrintUpdate(ThisApplication As Inventor.Application)
        ' Check if current document is a drawing, show error if not
        If ThisApplication.ActiveDocument.DocumentType <> Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
            MsgBox("ONLY FOR USE IN DRAWING DOCUMENTS", "Ilogic")
            Return
        ' Set reference to active document
        Dim oDDoc As DrawingDocument = ThisApplication.ActiveDocument
        ' Get referenced model document type (part or assembly)
        Dim refDocType As Inventor.DocumentTypeEnum = oDDoc.ReferencedDocuments(1).DocumentType
        Dim oFilePath As String = "P:\"
        Dim FileName As String
        Dim PN As String = oDDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value.ToString
        Dim DocName As String = oDDoc.DisplayName
        ' Check if document name matches part number
        If DocName <> (PN & ".idw") Then
            MsgBox("DOCUMENT NAME IS DIFFERENT FROM PART NUMBER")
            Return
        ' Count sheets
        Dim SheetCount As Integer = oDDoc.Sheets.Count
        ' Always export PDF
        If String.IsNullOrEmpty(oFilePath) Then
            MsgBox("This file has not yet been saved and doesn't exist on disk!" & vbCrLf & "Please save it first", 64, "Formsprag iLogic")
            Return
        FileName = PN & ".pdf"
        Dim pdfPath As String = oFilePath & "\" & FileName
        Dim oPDFAddin As Inventor.TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
        Dim oDocument As Inventor.Document = ThisApplication.ActiveDocument
        Dim oContext As Inventor.TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        Dim oOptions As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
        Dim oDataMedium As Inventor.DataMedium = ThisApplication.TransientObjects.CreateDataMedium
        ' Set PDF options
        oOptions.Value("All_Color_AS_Black") = 0
        oOptions.Value("Remove_Line_Weights") = 1
        oOptions.Value("Vector_Resolution") = 4800
        oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
        ' Set PDF target file name
        oDataMedium.FileName = pdfPath
        Try
            ' Publish document
            oPDFAddin.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
            ExportFirstPageAsImage(pdfPath, oFilePath & "\" & PN & ".jpg")
        Catch
            MsgBox("Failed to Export PDF (Someone might have this file open)", MsgBoxStyle.OkOnly)
            Return
        Finally
            If oContext IsNot Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(oContext)
            If oOptions IsNot Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(oOptions)
            If oDataMedium IsNot Nothing Then System.Runtime.InteropServices.Marshal.ReleaseComObject(oDataMedium)
            ' Do NOT release oPDFAddin
        End Try
        ' If referenced document is a part, convert PDF to JPG and then delete the PDF
        If refDocType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
            Try
                ' Delete the PDF after conversion
                If IO.File.Exists(pdfPath) Then
                    IO.File.Delete(pdfPath)
                MsgBox("Failed to convert PDF to JPG: " & ex.Message, MsgBoxStyle.OkOnly)
            End Try
    End Sub
End Module
Replies (0)
