Sketch Driven Pattern in a part file True / False
jletcher
Advisor Advisor
jletcher
 I have ilogic controlling the visibility of the occurrences as of now the code shown below has "true" turning them off and "false" showing the item.
I was wondering if there is a way to reverse the "True" - "False", client is finding this confusing seeing there are other true/false options and true turns the item on..
Dim oPattern As SketchDrivenPatternFeature
oPattern = ThisDoc.Document.ComponentDefinition.Features.SketchDrivenPatternFeatures.Item("900C7G")
Dim oElements As FeaturePatternElements = oPattern.PatternElements
oElements(2).Suppressed = G_F
oElements(3).Suppressed = G_G
oElements(4).Suppressed = G_H
oElements(5).Suppressed = G_I
oElements(6).Suppressed = G_J
oElements(7).Suppressed = G_K
oElements(8).Suppressed = G_L
oElements(9).Suppressed = G_M
oElements(10).Suppressed = G_N
oElements(11).Suppressed = G_P
oElements(12).Suppressed = G_Q
oElements(13).Suppressed = G_R
ThisDoc.Document.update
WCrihfield
Not entirely sure what you need, but here is something like what I'm thinking your asking for.
Of course it's untested, but the idea is fairly simple.
Sub Main
	oElements(2).Suppressed = RevBool(G_F)
	oElements(3).Suppressed = RevBool(G_G)
	oElements(4).Suppressed = RevBool(G_H)
	oElements(5).Suppressed = RevBool(G_I)
	oElements(6).Suppressed = RevBool(G_J)
	oElements(7).Suppressed = RevBool(G_K)
	oElements(8).Suppressed = RevBool(G_L)
	oElements(9).Suppressed = RevBool(G_M)
	oElements(10).Suppressed = RevBool(G_N)
	oElements(11).Suppressed = RevBool(G_P)
	oElements(12).Suppressed = RevBool(G_Q)
	oElements(13).Suppressed = RevBool(G_R)
	ThisDoc.Document.updateElement.Suppressed = False
End Sub
Function RevBool(ByVal oBool As Boolean) As Boolean
	If oBool = True Then oBool = False Else oBool = True
Return oBool
End Function
Wesley Crihfield
(Not an Autodesk Employee)
jletcher
Thanks for the reply, unfortunately that did not work.
The () are not allowed as a parameter name so I took them out and tried but it still has false as being turned on.
 I'll try to clear it up.
 The code I provided allows me to control the visibility of  each pattern occurrence, in my form I have a check box that toggles what ones to turn on and off.  As of now the code I provided has False as default to turn the visibility on and true to turn them off. So if the client wants to show the spacer in "G_G" location he unchecks the check box (False) and that is backwards to the rest of the check box commands saying "True" turns on the visibility..
I was hoping to reverse the "True" and the "False" where "True" would be turning on the visibility.
 Hope that clears it up some..
jletcher
Here is a sample part.
When you start the form you will notice the check boxes are uncheck and the spacers are show. If you put a check mark in it turns them off. This is what I would like to reverse, I want it to be checked to show and no check to turn them off.
JhoelForshav
Hi @jletcher
Do I understand correctly that you just want to flip it so that for example G_F = false will suppress the element at index 2?
Something like this then?
oElements(2).Suppressed = If (G_F, False, True)
oElements(3).Suppressed = If (G_G, False, True)
oElements(4).Suppressed = If (G_H, False, True)
oElements(5).Suppressed = If (G_I, False, True)
oElements(6).Suppressed = If (G_J, False, True)
oElements(7).Suppressed = If (G_K, False, True)
oElements(8).Suppressed = If (G_L, False, True)
oElements(9).Suppressed = If (G_M, False, True)
oElements(10).Suppressed = If (G_N, False, True)
oElements(11).Suppressed = If (G_P, False, True)
oElements(12).Suppressed = If (G_Q, False, True)
oElements(13).Suppressed = If (G_R, False, True)
jletcher
Perfect, thank you, thank you
Not sure if I would have figured that one out..
