Skeleton Sketch is not update
Pratik.Ksoni
Pratik.Ksoni
i have created one Assembly with the help of skeleton sketch, when i change the value then few values from skeleton sketch are not update.
to update the value i need to run the rule and i have already created trigger also.
in the current scenario i have created one button and in this button i have created rules to update required Rules but this is not standard practice to work on iLogic.
Please guide me.
Pratik
HermJan.Otterman
Hello Pratik
can you share you assembly?
did you create a part in it with the skeleton sketch?
where is the sketch, and where are the values that you change?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
