Hello all,
I'm working on auto generate pdf/dxf for inventor files with iLogic. For so far it's creating pdf and dxf as I wanted it to create, the difficulty was in the creation of dxf with the *.ini file and layers visible and invisible. But it works fine now. The thing is that the sometimes I want to have a single laser line in the *.dxf. I've found a work around of creating this with editing the flat pattern; made a extrusion and over that extrusion a sketch; with creating *.dxf I made the 'IV_UNCONSUMED_SKETCHES:Visibility=ON' so it's visible on the dxf. Problem solved I thought.
Now I get the product in my hand and the single laser line isn't cut 😞 the thing is that it is in a different layer (in the *.dxf file) so the laser program did not used it for its program. So I can asked the laser machine man to pay attention on the different layers or what I thing should be a better solution to let Inventor Merge the unconsumed sketches with Interior_Profile layer. This is possible with AutoCAD Mechanical so I hope Inventor can do this to in its save copy as... *.dxf.
Please let my know if you know how this is possible.
Best Regards,
Bram
