Simple view label text change.... wont work?
brian
brian
Hi Guys,
I have some pretty basic code here that I want to select a view and have the label text updated. But the code wont work, I havent used VBA for a long time and cant remember why this wont work when directly referenced as below?
Any help would be appreciated...
Public Sub ISO_VIEW()
Dim dwgdoc As DrawingDocument
Set dwgdoc = ThisApplication.ActiveDocument
Set dwgdoc.SelectSet.Item(1).Label.Text = "HELLO WORLD"
End Sub
brian
hmmmm, I really confused with this....
I now have the following code and the dwg view shading works fine, but the second command to change the text fails.....
Dim myview As DrawingView
Set myview = dwgdoc.SelectSet.Item(1)
myview.ViewStyle = kShadedDrawingViewStyle
myview.Label.Text = "HELLO WORLD"
End Sub
YuhanZhang
The DrawingViewLabel.Text now is read-only property. You can use the FormattedText instead.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
brian
Thanks so much, I missed that property completley Lol.
Bri
