ShrinkWrap with RemoveHolesStyle and RemovePocketsStyle
klaus.kapeller
klaus.kapeller
when creating a shrinkwrap without these 2 remove features, everything works fine.
When creating a shrinkwrap with one of these features, everything works also fine.
But when I turn on both, I always get an error:
Error HRESULT E_FAIL has been returned from a call to a COM component
Works:
$ShRDef.RemoveHolesStyle = [Inventor.ShrinkwrapRemoveStyleEnum]::kShrinkwrapRemoveNone
$ShRDef.RemovePocketsStyle = [Inventor.ShrinkwrapRemoveStyleEnum]::kShrinkwrapRemoveNone
Works:
$ShRDef.RemoveHolesStyle = [Inventor.ShrinkwrapRemoveStyleEnum]::kShrinkwrapRemoveByRange
$ShRDef.RemoveHolesDiameterRange = 8
Works:
$ShRDef.RemovePocketsStyle = [Inventor.ShrinkwrapRemoveStyleEnum]::kShrinkwrapRemoveByRange
$ShRDef.RemovePocketsMaxFaceLoopRange= 25
Does not work:
$ShRDef.RemovePocketsMaxFaceLoopRange = 25
Has anyone any idea or experience getting that stuff working?
And as I found in an example, the values for the range must be used in cm...is that correct?
Thanks for your help...
Klaus
Hi Klaus
I just tested the code below, it seems to do what you are looking for.
Sub createShrinkWrapWithDefinition()
Dim oApp As Application
Dim oAD As AssemblyDocument
Dim oACD As AssemblyComponentDefinition
Set oApp = ThisApplication
Set oAD = oApp.ActiveDocument
Set oACD = oAD.ComponentDefinition
oPath = oAD.FullDocumentName
Dim oPartDoc As PartDocument
Dim oPCD As PartComponentDefinition
Dim ShRDef As ShrinkwrapDefinition
Dim ShrComp As ShrinkwrapComponent
Set oPartDoc = oApp.Documents.Add(kPartDocumentObject, , True)
Set oPCD = oPartDoc.ComponentDefinition
Set ShRDef = oPCD.ReferenceComponents.ShrinkwrapComponents.CreateDefinition(oPath)
ShRDef.ActiveDesignViewRepresentation = "Default"
ShRDef.ActiveLevelOfDetailRepresentation = "Master"
ShRDef.ActivePositionalRepresentation = "Master"
'Call ShRDef.AdditionalExcludedOccurrences.Add(Object) 'Need User Selection
'Call ShRDef.AdditionalIncludedOccurrences.Remove(Object)'Need User Selection
ShRDef.BreakLink = False
ShRDef.CreateIndependentBodiesOnFailedBoolean = True
ShRDef.DeriveStyle = kDeriveAsSingleBodyWithSeams
ShRDef.IsAssociativeDesignView = False
'Call ShRDef.PreservedFeatures.Add(Object) 'Need User Selection
ShRDef.RemoveAllInternalVoids = False
ShRDef.RemoveChamfersDistanceRange = 10 'cm
ShRDef.RemoveChamfersStyle = kShrinkwrapRemoveByRange
ShRDef.RemoveFilletsRadiusRange = 10 'cm
ShRDef.RemoveFilletsStyle = kShrinkwrapRemoveByRange
ShRDef.RemoveHolesDiameterRange = 10 'cm
ShRDef.RemoveHolesStyle = kShrinkwrapRemoveByRange
ShRDef.RemoveInternalParts = False
ShRDef.RemovePartsBySize = True
ShRDef.RemovePartsSize = 10 'cm
ShRDef.RemovePocketsMaxFaceLoopRange = 10 'cm
ShRDef.RemovePocketsStyle = kShrinkwrapRemoveByRange
ShRDef.RenameComponent = True
ShRDef.UseColorOverrideFromSourceComponent = True
Set ShrComp = oPCD.ReferenceComponents.ShrinkwrapComponents.Add(ShRDef)
End Sub
This was originally posted here:
https://forums.autodesk.com/t5/inventor-customization/how-to-use-shrinkwrapcomponents-and-shrinkwrap...
