Show total mass automatically in Parts list
MikeKovacik4928
Advisor Advisor
Message 1 of 17
MikeKovacik4928
Hi inventor users around the globe & Autodesk employees
see jpeg below for details of what I would like to do.
IQ_134_Total Weight on BOM_013.jpg Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Authorised Autocad & Inventor Professional
Authorised Autodesk Trainer
Higher Diploma Mechanical Engineering
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Replies (16)
Message 2 of 17
mdavis22569
So you want a total mass option added to the parts list at the bottom?
You have it showing up for each part, which is good, but now you just need that last part?
What about making a virtual part via iLogic calling it Total Mass, giving the weight value of what you have to the assembly you're in ... total mass.
Mike Davis
Message 3 of 17
MikeKovacik4928
Not Solved Yet
My fault
Sorry Michael for not replying
I don't know how to make a virtual part using ilogic, can you explain
Your idea sounds good, I would like to give it a try
Mike
Message 4 of 17
mrattray
Would it be acceptable to have the total mass displayed somewhere other than your parts list? If you create a text note somewhere on your drawing you can pull up the total mass of your assembly as a linked property.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Mike (not Matt) Rattray
Message 5 of 17
mdavis22569
Sorry @MikeKovacik4928 for my delay ....
Have you had a moment to look at or try my suggestion?
I can try it too...
Mike Davis
Message 6 of 17
MikeKovacik4928
Thanks Mike
No I need it to appear as the bottom of the bom as the last row and automatically add
up the masses of all the parts multiplied by their number of instances.
Something that is quite easily done in excel, just not possible out of the box in Inventor, unfortunately
Mike
Message 7 of 17
MikeKovacik4928
Mike
Not had a chance to try it yet
I don't know how to create a virtual part using illogic.
I will have a look today
Mike
Message 8 of 17
MikeKovacik4928
Mike
Here is how I have done it using virtual component but not using iLogic and filling in things manually. Definitely far from ideal and not automatic.
I would like to take it one step further and automate it using ilogic. However I am new to ilogic and never used it before.
Mike
Message 9 of 17
mdavis22569
Curtis is the iLogic guru ...
He might be able to come up with the workflow that would work for that ...
Mike Davis
Message 10 of 17
basnederveen
Not iLogic, and a different approach. Here's a macro that:
- asks you to pick an assembly view
- adds row to partslist (assumes there is only one in the sheet)
- puts the assembly mass in the last row
- if there is already a row with total mass in the parts list, it updates the mass
You might have to change the numbers 3 and 4, these are the column numbers.
Sub testTotalMass()
Dim dwg As DrawingDocument
Set dwg = ThisApplication.ActiveDocument
Dim oview As DrawingView
Set oview = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Pick the assembly view")
On Error Resume Next
Dim asm As AssemblyDocument
Set asm = oview.ReferencedDocumentDescriptor.ReferencedDocument
If Err Then
    MsgBox ("Not an assembly")
    Exit Sub
Dim pl As PartsList
Set pl = dwg.ActiveSheet.PartsLists.Item(1)
Dim plr As PartsListRow
Dim found As Boolean
For Each plr In pl.PartsListRows
    If plr.Item(3).Value = "TOTAL MASS" Then
        found = True
        Exit For
Next
Dim txn As Transaction
Set txn = ThisApplication.TransactionManager.StartTransaction(dwg, "Add total mass")
If found = False Then Set plr = pl.PartsListRows.Add(pl.PartsListRows.count, False)
plr.Item(4).Value = Round(asm.ComponentDefinition.MassProperties.mass, 2) & " kg"
txn.End
End Sub
Message 11 of 17
MikeKovacik4928
basnerdeveen
1. How do I load this
2. How do I run it
Mike
Message 12 of 17
basnederveen
Press Alt + F11 -> paste the code in a module -> create a shortcut by right clicking the ribbon -> customize user commands -> choose 'macros' in the dropdown -> pick the macro you just added -> press the button
Message 13 of 17
MikeKovacik4928
Basnederveen
Works beautifully
Mike
Message 14 of 17
anoor
Michael,
After you create your B.O.M., you'll need to do the following:
- Select column chooser in top left corner
- Select New Property and Name it 'Total Mass'
- Add it to your selected properties
- Click 'OK', then right click the 'Total Mass' column and select 'Format Column'
- Click the substitution tab and select 'Enable Value Substition'
- Click the drop down menu and select the 'MASS' property
- Under 'When rows are merged, value used is' drop down menu, select 'Sum of Values'
You can follow these steps for each bill you create, or you can follow these steps in your styles editor for your template file and it will show up automatically when you place a B.O.M. on the drawing.
Message 15 of 17
claudio.ibarra
What are the advantages/disadvantages to putting the code in Modules after hitting Alt+F11 vs putting the same code in iLogic rules?
Message 16 of 17
EMVC
Hello
is i possible to get partname in Partslist table(Title) in this macro se also pisture
Sub testTotalMass()
If Err Then
    Exit Sub
Dim pl As PartsList
        found = True
        Exit For
Next
txn.End
Message 17 of 17
jeffi
Observer
Observer
Is there any way to add this logic if I have multiple assemblies on one drawing?
When I run the macro on the second assembly, it adds another Total Weight to the first BOM. Also, the summation is not correct. The total weight should be 44.2 and it shows up as 20.0.
Jeff I.
