Show Thumbnail in the Windows.Forms.PictureBox iLogic Inventor 2026
pavol_krasnansky1
pavol_krasnansky1
Hi, the iLogic rule below works in Inventor 2023 and does not work in Inventor 2026. Why? What should I change?
Imports System.Windows.Forms
Imports System.IO
Imports System.Windows.Imaging
Imports System.Windows.Graphics
Imports System.Drawing
Imports Microsoft.VisualBasic
AddReference "System.Drawing.dll"
AddReference "Microsoft.VisualBasic.Compatibility.dll"
AddReference "Microsoft.VisualBasic.dll"
AddReference "stdole.dll"
Sub Main()
	Dim oThumbnail As IPictureDisp = ThisDoc.Document.Thumbnail
	' oForm
	Dim oForm As New System.Windows.Forms.Form
	oForm.Text = "Thumbnail Inventor 2026"
	oForm.Size = New Drawing.Size(350, 400)
	oForm.Font = New Drawing.Font("Arial", 10)
	' oForm.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedSingle
	oForm.StartPosition = FormStartPosition.CenterScreen
	oForm.ShowIcon = False
	oForm.HelpButton = False
	oForm.MaximizeBox = True
	oForm.MinimizeBox = True
	oForm.Margin = New System.Windows.Forms.Padding(0, 0, 0, 0) ' Vonkajšie: Left, Top, Right, Bottom
	oForm.Padding = New System.Windows.Forms.Padding(0, 0, 0, 0) ' Vnútorné: Left, Top, Right, Bottom
	' TableLayoutPanel1
	Dim TableLayoutPanel1 As New System.Windows.Forms.TableLayoutPanel
	TableLayoutPanel1.ColumnCount = 1
	TableLayoutPanel1.RowCount = 1
	TableLayoutPanel1.ColumnStyles.Add(New System.Windows.Forms.ColumnStyle(System.Windows.Forms.SizeType.Percent, 100.0!))
	TableLayoutPanel1.RowStyles.Add(New System.Windows.Forms.RowStyle(System.Windows.Forms.SizeType.Percent, 100.0!))
	TableLayoutPanel1.Dock = System.Windows.Forms.DockStyle.Fill
	TableLayoutPanel1.Margin = New System.Windows.Forms.Padding(5, 5, 5, 5) ' Vonkajšie: Left, Top, Right, Bottom
	TableLayoutPanel1.Padding = New System.Windows.Forms.Padding(5, 5, 5, 5) ' Vnútorné: Left, Top, Right, Bottom
	oForm.Controls.Add(TableLayoutPanel1)
	' oPictureBox
	Dim oPictureBox As New System.Windows.Forms.PictureBox
	oPictureBox.SizeMode = PictureBoxSizeMode.Zoom ' CenterImage
	oPictureBox.Dock = System.Windows.Forms.DockStyle.Fill
	oPictureBox.Margin = New System.Windows.Forms.Padding(5, 5, 5, 5) ' Vonkajšie: Left, Top, Right, Bottom
	oPictureBox.Padding = New System.Windows.Forms.Padding(0, 0, 0, 0) ' Vnútorné: Left, Top, Right, Bottom
	TableLayoutPanel1.Controls.Add(oPictureBox, 0, 0)
	Dim oThumbnail_Image As System.Drawing.Image
	oThumbnail_Image = Compatibility.VB6.IPictureDispToImage(oThumbnail)
	Dim oThumbnail_Bitmap As New Bitmap(500, 500)
	Dim oThumbnail_Resize As System.Drawing.Graphics = Graphics.FromImage(oThumbnail_Bitmap)
	Try
		oThumbnail_Resize.DrawImage(oThumbnail_Image, 0, 0, 500, 500)
	Catch ex As Exception
		'MsgBox(ex.ToString)
	End Try
	oPictureBox.Image = oThumbnail_Bitmap
	oThumbnail_Image = Nothing
	oThumbnail_Resize = Nothing
	oThumbnail_Bitmap = Nothing
	oForm.ShowDialog()
End Sub
Andrii_Humeniuk
Hi @pavol_krasnansky1 .
This is due to the fact that Inventor from version 2025 migrated from .Net Framework to .Net core 8. You can read more about this at the link, link. Regarding your problem, I recommend reading the following topic. If you use the tips, your code should look something like this:
Imports System.IO
'AddReference "Microsoft.VisualBasic.Compatibility.dll"
Sub Main()
	' oForm
	' TableLayoutPanel1
	' oPictureBox
	oThumbnail_Image = PictureDispToImage(oThumbnail)
	Try
	End Try
	oForm.ShowDialog()
End Sub
Public Shared Function PictureDispToImage(pictureDisp As stdole.IPictureDisp) As System.Drawing.Image
	Dim oImage As System.Drawing.Image
	If pictureDisp IsNot Nothing Then
		If pictureDisp.Type = 1 Then
			Dim hpalette As IntPtr = New IntPtr(pictureDisp.hPal)
			oImage = oImage.FromHbitmap(New IntPtr(pictureDisp.Handle), hpalette)
		If pictureDisp.Type = 2 Then
			oImage = New System.Drawing.Imaging.Metafile(New IntPtr(pictureDisp.Handle), New System.Drawing.Imaging.WmfPlaceableFileHeader())
	Return oImage
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
