Show if there is an DWG associated or not
Is there any iLogic or VB that can tell me for an specific assembly what parts/assemblies do not have an associated DWG?
see idea:
http://forums.autodesk.com/t5/inventor-ideastation/show-if-there-is-an-dwg-associated-or-not/idi-p/6...
NSBowser
Unlike how a drawing is aware of which parts/assemblies it references, there is no real link from a Part or Assembly to any corresponding drawings. When you right click on the browser and select 'Open Drawing' it simply checks the workspace for a .idw file with the same name as the corresponding file.
IF your situation allows it, you can use the same logic to determine which files have drawings.
Loop through all the parts/assemblies in your assembly and check for each filename if the corresponding .idw exists.
I created a lightweight program for our users that works like a custom Windows Explorer. When a folder is navigated to it lists all of the Filenames in the first column and then each file type in subsequent columns. Something like that might be a solution for you as well.
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
rossano_praderi
Hi Goncalves,
@NSBowser mean something like the follow code
This Add the text "(IDW)" or "(DWG)"
On Error Resume Next
Dim oAss As AssemblyDocument = ThisApplication.ActiveEditDocument
Dim bp As BrowserPane = ThisApplication.ActiveDocument.BrowserPanes.ActivePane
Dim node As BrowserNode
Dim oName As String
For Each node In bp.TopNode.BrowserNodes
    oName = Left(node.NativeObject.Definition.Document.FullFileName, _
                Len(node.NativeObject.Definition.Document.FullFileName) - 3)
    If System.IO.File.Exists(oName & "idw") Then
        node.NativeObject.Name = node.NativeObject.Name.Replace("(IDW) ", "")
        node.NativeObject.Name = ("(IDW) " & node.BrowserNodeDefinition.Label)
    If System.IO.File.Exists(oName & "dwg") Then
        node.NativeObject.Name = node.NativeObject.Name.Replace("(DWG) ", "")
        node.NativeObject.Name = ("(DWG) " & node.BrowserNodeDefinition.Label)
Next
This clean the added text
Dim oName As String
    If InStr(1, node.BrowserNodeDefinition.Label, "(DWG) ") > 0 Then
        node.NativeObject.Name = node.BrowserNodeDefinition.Label.Replace( "(DWG) ", "")
    If InStr(1, node.BrowserNodeDefinition.Label, "(IDW) ") > 0 Then
        node.NativeObject.Name = node.BrowserNodeDefinition.Label.Replace( "(IDW) ", "")
Next
I hope you like it, is not perfect but work fine for me.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
rossano_praderi
did you tried my code?
