Show a Text Suffix in an InputListBox
arkelec
arkelec
Is it possible to show the text (in green) as per the List Box shown below?  The data required by the wider iLogic, is the two digit text in black.  It's just not easy to remember what the code represents (there are a lot more entries in the full version).
I can add the whole line as one string, then only select the first two characters from the left in the main iLogic code, but  is there a better way?
ckeveryga
I believe this is what you're looking for.
WCrihfield
How about this?
Dim oOptions As New List(Of String)
oOptions.Add("01   General")
oOptions.Add("02   Cable")
oOptions.Add("03   Cable Assy")
oOptions.Add("04   Cable Glanding")
Dim oChoice As String = InputListBox("Choose one.", oOptions, oOptions.Item(1), "OPTIONS")
If oChoice.Contains("01") Then
	MsgBox("You chose 'General'.", vbOKOnly, "CHOICE")
ElseIf oChoice.Contains("02") Then
	MsgBox("You chose 'Cable'.", vbOKOnly, "CHOICE")
ElseIf oChoice.Contains("03") Then
	MsgBox("You chose 'Cable Assy'.", vbOKOnly, "CHOICE")
ElseIf oChoice.Contains("04") Then
	MsgBox("You chose 'Cable Glanding'.", vbOKOnly, "CHOICE")
Wesley Crihfield
(Not an Autodesk Employee)
