Sheet size selection
sbell7ENRD
sbell7ENRD
I have created A0, A1, A2 & A3 templates in Inventor, how do I create a pop up to allow me to choose which size sheet to use when opening the templates?
Is it possible to create a pop up, that asks you to complete the ilogic/drawing details when saving?
Thanks 🙂
CCarreiras
Hi!
Unless the drawings have deep differences between them, you don't have to create templates for each size, you can change the size for each sheet in the same document/template after opening.
This way, if you have to change the sheet size, you don't have to open another template and lose all the work, you just have to select a new size.
CCarreiras
A.Acheson
Like @CCarreiras  has stated make all the sheet sizes in one template.
If you want some ilogic knowledge type Ilogic drawing automation into the internet explorer and you should get lots of hits relating to this forum and to other companies who kindly share sample rules. A internet search of ilogic drawing sheet size change will get you lots of examples.
Here is a somewhat advance rule.
https://microconcepts.typepad.com/design_automation/2015/09/change-sheet-size-update-title-block-and...
The other method is to jump into the ilogic rule editor, find drawing in the category browser and pull out the relevant snippets. I would suggest an external rule as you will likely want to modify the code externally to the drawing.
In addition you will need a parameter sheet size in the drawing to change sheet size. Then I would suggest you create an external form and drag the sheet size parameter into the form.
Regards
Alan
