Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Sheet metal style - material
Message 1 of 12
How can I set the material of a sheet metal part with VB6 to "By sheet metal rule"?
On Error GoTo ErrorHandler
Dim oPartDoc As PartDocument
Set oPartDoc = objInventorApp.ActiveDocument
'selecteer sheet metal component definition.
Dim oSheetMetalCompDef As SheetMetalComponentDefinition
Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
oSheetMetalCompDef.Material = ???????
Geert
Replies (11)
Message 2 of 12
Anybody?
See attached example!
Message 3 of 12
Hi Geert:
Please refer to my VBA code to set the existent
material of the sheet metal document:
Sub test()
    Dim oSM As
PartDocument
    Set oSM =
ThisApplication.ActiveDocument
    Dim
oSMCompDef As SheetMetalComponentDefinition
    Set oSMCompDef
= oSM.ComponentDefinition
    Dim
oMaterial As Material
    Set oMaterial = oSM.Materials(1)
'Get the material via Index or its
name
    oSMCompDef.Material =
oMaterial
End Sub
Also you can create a custom material via the
following VBA code extracted from the API help:
[Material Create Example (Visual Basic)] This
sample demonstrates how to create a new material in a part document. Before
running the sample you must have a part document open.
Public
class=keyword>Sub
CreateMaterial()
class=comment>' Set a reference to the part
document.
    ' This
assumes a part document is active.
class=keyword>Dim
oPartDoc As
PartDocument
    Set
oPartDoc =
class=comment>' Create a new
material.
    Dim
oNewMaterial As
Material
    Set
oNewMaterial = oPartDoc.Materials.Add("My
Material"
, 11.37)
class=comment>' Define the other properties of the
material
    oNewMaterial.LinearExpansion =
5.73
    oNewMaterial.PoissonsRatio =
0.38
    ' Arbitrarily assigns
the first render style in the render styles
collection.
    oNewMaterial.RenderStyle =
oPartDoc.RenderStyles.Item(1)
    oNewMaterial.SpecificHeat
= 124.3
    oNewMaterial.ThermalConductivity =
310.2
    oNewMaterial.UltimateTensileStrength =
210.45
    oNewMaterial.YieldStrength =
185.5
    oNewMaterial.YoungsModulus =
76.37
End
class=keyword>Sub
How
rule"? On Error GoTo ErrorHandler Dim oPartDoc As PartDocument Set oPartDoc =
objInventorApp.ActiveDocument 'selecteer sheet metal component definition. Dim
oSheetMetalCompDef As SheetMetalComponentDefinition Set oSheetMetalCompDef =
oPartDoc.ComponentDefinition oSheetMetalCompDef.Material = ??????? Regards,
Geert
Message 4 of 12
Hi Lisa,
Thanks for your reply, but when I use Set oMaterial = oSM.Materials(1) or Set oMaterial = oSM.Materials("ST37"),
the material style is exactly set to ST37 or the first one in the materials collection.
When I then change my Sheet Metal Rule to "2mm Aisi304" the material stays on ST37 and doesn't follow the rule anymore.
Therefore you have in Inventor 2009 the option "{color:#ff0000}By Sheet Metal Rule ( ....)"{color} (.... is material name)
My problem is that I want to set the Material Style on the option "{color:#ff0000}By Sheet Metal Rule ( ST37 )"{color} by VB6 See also my attached file in my earlier reply.
Hopefully you know how to do this.
Geert
Message 5 of 12
Hi Geert,
I can't find the materials "ST37", "2mm Aisi304"
from the material library on my inventor.
I'm using Inventor 2009.
Do you create these materials by yourself?
-Lisa
Hi Lisa,
When I then
Geert
Message 6 of 12
Hi Lisa,
Yes, I created these materials myself through the style library in Inventor. But that's just a example.
You may try it with your own material. For instance "Gray Iron".
You can set the desired material by VB6 to "Gray Iron" but that's not what I want.
I want to set it By Sheet Metal Rule (Gray Iron), so the material follows always the choosen sheet metal rule.
My VB6 routine converts a part to a sheet metal part, creates several sheet metal styles, Unfold metods, etc. we use in our company.
On the end I set one style active, but I can't get set the material style on {color:#ff0000}By Sheet Metal Rule ( Gray Iron )
{color}
Kind Regards,
Geert
Message 7 of 12
Here's some code that will change the material
associated with the active sheet metal rule.
Public Sub
SetSheetMetalStyleMaterial()
    Dim oDoc As
PartDocument
    Set oDoc =
    Dim
oSMDef As SheetMetalComponentDefinition
    Set oSMDef =
oDoc.ComponentDefinition
oSMDef.ActiveSheetMetalStyle.Material = oDoc.Materials.Item("Gold")
End
Sub
Brian Ekins
Autodesk Inventor API
href="http://blogs.autodesk.com/modthemachine">http://blogs.autodesk.com/modthemachine
Message 8 of 12
I got your meaning now, in
fact you just need to set the SheetMetalStyle's Material.
When selecting a new SheetMetalStyle(In UI:Sheet
Metal Rule), there will be a Material associated with the style.
face="Courier New">
Please try the following code to set the
Material to "By Sheet Metal Rule (Gray Iron)":
Sub test()
    Dim oSM As
PartDocument
    Set oSM =
    Dim
    Set oSMCompDef
    Dim
oStyle As SheetMetalStyle
    Set oStyle =
oSMCompDef.ActiveSheetMetalStyle 'Use the current
SheetMetalStyle
    Dim oMaterial As
Material
    Set oMaterial = oSM.Materials("Gray
Iron")
    oStyle.Material =
oMaterial
End Sub
-Lisa
Hi
Lisa,
rule.
On the end I
{color}
Kind
Geert
Message 9 of 12
Hi Lisa, Brain,
These code you suggested I already had, but this sets the material style on "Default" and not on "By Sheet Metal Rule"
(see also my attached file)
Here is my complete code to make several SM styles and make one of them active.
In INV 2008 it works fine, but then there wasn't the option "By sheet metal rule" in INV 2008
(e.g. "- St 37" is a custom made Material)
I hope you can help me with this.
Geert
Sub Create_All_SM_Styles()
CreateSheetMetalStyle "1.5 mm", "- St 37", 15, "0.407", False, False, True
CreateSheetMetalStyle "2 mm", "- St 37", 20, "0.321", True, False, True
CreateSheetMetalStyle "3 mm", "- St 37", 30, "0.246", False, False, True
CreateSheetMetalStyle "4 mm", "- St 37", 40, "0.201", False, False, False
CreateSheetMetalStyle "5 mm", "- St 37", 50, "0.198", False, False, False
CreateSheetMetalStyle "6 mm", "- St 37", 60, "0.175", False, False, False
CreateSheetMetalStyle "8 mm", "- St 37", 80, "0.152", False, False, False
CreateSheetMetalStyle "10 mm", "- St 37", 100, "0.143", False, False, False
End Sub
Public Sub CreateSheetMetalStyle(strStyleNaam As String, strMateriaal As String, dPlaatdikte As Double, strKFactor As String, bolActivate As Boolean, bolLast As Boolean, bRadius_2mm As Boolean)
' On Error GoTo ErrorHandler
Dim oStyle As SheetMetalStyle
On Error Resume Next
Set oStyle = oSheetMetalCompDef.SheetMetalStyles.Copy(oSheetMetalCompDef.SheetMetalStyles.It em(1), strStyleNaam)
Dim oMaterial As Inventor.Material
Set oMaterial = oPartDoc.Materials.Item(strMateriaal)
oStyle.Material = oMaterial
Dim okFactorUnfoldMethod As UnfoldMethod
Set okFactorUnfoldMethod = oSheetMetalCompDef.UnfoldMethods.AddLinearUnfoldMethod(strStyleNaam & "_KFactor", strKFactor) oStyle.UnfoldMethod = okFactorUnfoldMethod
oStyle.Thickness = dPlaatdikte / 10
Dim sThicknessName As String
sThicknessName = oSheetMetalCompDef.Thickness.Name
oStyle.BendReliefShape = ""
oStyle.BendReliefWidth = sThicknessName
oStyle.BendReliefDepth = sThicknessName & " * 0.5"
oStyle.MinimumRemnant = sThicknessName & " * 2.0"
If bRadius_2mm = True Then
oStyle.BendRadius = "2 mm"
Else
oStyle.BendRadius = sThicknessName
oStyle.BendTransition = kIntersectionBendTransition
oStyle.CornerReliefShape = kTearCornerReliefShape
oStyle.CornerReliefSize = sThicknessName & " * 4.0"
' Activate this style and set Material Syle -> {color:#ff0000}By Sheet Metal Rule (- St 37)
{color}If bolActivate = True Then
oStyle.Activate
oSheetMetalCompDef.ActiveSheetMetalStyle.Material = oMaterial
If bolLast = True Then
' Set oStyle = oSheetMetalCompDef.ActiveSheetMetalStyle 'Use the current SheetMetalStyle
' Set oMaterial = oPartDoc.Materials.Item("- St 37")
' oStyle.Material = oMaterial
oPartDoc.Update
End Sub
Message 10 of 12
I just saw that my code isn't complete (I had changed one line for testing your input)
oStyle.Activate
It must be:
oStyle.Activate
oSheetMetalCompDef.Material = oMaterial 'sets the parts Material, in my case, hard on "- St 37" but not on {color:#ff0000}By Sheet Metal Rule (- St 37){color} End If
Message 11 of 12
Sorry, I didn't understand the question
initially.  To get the sheet metal part to use the material defined by the
sheet metal rule set the
SheetMetalComponentDefinition.UseSheetMetalStyleMaterial property to True.
Brian Ekins
Message 12 of 12
Hi Brian,
Thanks, that's it.
I just overlooked these new properties.
Kind Regards,
Geert
