Sheet Metal Flatpattern Info
rhutchins
Message 1 of 22
rhutchins
Ok I have searched and searched for this and I cannot find anything it is possible in AutoCAD but I cannot find a way to automate it in Inventor or actually even do it in inventor, what I would like is to be able to get a "Total Linear" cut length of a sheet metal part - all perimeters of cuts, holes, what ever shows up in the flat pattern I would use this info for quoting of parts that I draw currently I have to create a flat pattern save to AutoCAD as dwg or dxf clean up the file so only the Items that the laser will be cutting are in the drawing, then I have a code I found in the AutoCAD customize discussion group that will allow me to select a bunch of enities and it computes the total length of all lines arcs circles ..... that I select then I take that value and type it into a "User Defined" sketched symbol in my IDW. if anyone knows of any way to get this info using inventor that is easy please help.
Replies (21)
Message 21 of 22
That's real easy then just get the length and width and multiply them? Am I
missing something?
Brian Ekins
Autodesk Inventor API
Message 22 of 22
No, you haven't missed anything. I will multiply Length x Width and that gives me what I need.
I was just looking for
kSheetMetalFlatPatternArea Area extents of the flat pattern (Length x Width) 78851
I assumed that Area was exposed like Length and Width was. I have everything I need.
Thx,
-AllenG
