Sheet Metal Flat Pattern view insert in IDW code
I am working on a new iLogic rule that will create and IDW with automate views of the folded model of the sheet metal part in front view, right view, top view and the flat pattern I have success with all views except the flat pattern view creation codes. Does anyoone have knowledge of what the code terminology is to add a flat pattern view through ilogic to an idw?
Also, if this is possible, I want to create  a bend table and a hole table using ilogic to automate these processes.
So far, I can create any view off the folded model but I do not know the code to create a flat pattern view.
Please help.
MegaJerk
I don't remember where I found this code, but at one time I had the same question.
I hope that this helps!
Public Sub AddFlatPatternDrawingView()
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Create a new NameValueMap object
    Dim oBaseViewOptions As NameValueMap
    Set oBaseViewOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Set the options to use when creating the base view.
    Call oBaseViewOptions.Add("SheetMetalFoldedModel", False)
    ' Open the sheet metal document invisibly
    Dim oModel As Document
    Set oModel = ThisApplication.Documents.Open("C:\Some\Crazy\Path\To\Your\Part\Here.ipt", False)
    ' Create the placement point object.
    Dim oPoint As Point2d
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    ' Create a base view.
    Dim oBaseView As DrawingView
    Set oBaseView = oSheet.DrawingViews.AddBaseView(oModel, oPoint, 1, _
    kDefaultViewOrientation, kHiddenLineRemovedDrawingViewStyle, _
    , , oBaseViewOptions)
End Sub
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Thank you for your code. However, I was not able to make it work in Inventor 2012 Ilogic. I cleaned it up and removed the "SET" statements that are no longer used but I keep getting an error:
"Error in rule: FLAT PATTERN VIEW CREATE IN IDW, in document: FLAT PATTERN VIEW CREATE IN IDW.iLogicVb
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.DrawingDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D467-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
The codes I have currently that work and create the formed views of the sheet metal part is as follows:
'------------------------start of iLogic code ---------------------
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawingDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oView1 as DrawingView
Dim oView2 as DrawingView
Dim oView3 as DrawingView
Dim oView4 as DrawingView
'GET SHEET METAL FLAT PATTERN EXTENTS LENGTH TO CALCULATE VIEW SCALES
                            'MessageBox.Show(iProperties.Value("Custom","FlatExtentsLength"), "Title")
                            'MessageBox.Show(iProperties.Value("Custom","FlatExtentsWidth"), "Title")
FLATPATTERNLENGTH = iProperties.Value("Custom","FlatExtentsLength")
FLATPATTERNWIDTH = iProperties.Value("Custom","FlatExtentsWidth")
'Calculate View Scale
If FLATPATTERNLENGTH >= FLATPATTERNWIDTH Then
ViewScale = 5/FLATPATTERNLENGTH
Else
ViewScale = 5/FLATPATTERNWIDTH
'Ask to create drawing?
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
    oPartDoc = ThisDoc.Document
    'Define IDW Template File Location
    oDrawingDoc = ThisApplication.documents.Add(kDrawingDocumentObject, "pathandfilename.IDW", True)
    oSheet = oDrawingDoc.Sheets.Item(1)
    'Define 2d view bottom left corner points for four views
    oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(25#, 15#)
    oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(33#, 15#)
    oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(25#, 20#)
    oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(4#, 10#)
                oView1 = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kFrontViewOrientation, _
                kHiddenLineRemovedDrawingViewStyle)', KTANGENTEDGESON)
                oView2 = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint2, _
ViewScale,kRightViewOrientation,kHiddenLineRemovedDrawingViewStyle)
                oView3 = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint3, _
ViewScale,kTopViewOrientation,kHiddenLineRemovedDrawingViewStyle)
'-----------------------Flat Pattern View Section-------------------------------------------------------------------------
'This is the code line which I wish to use to add the sheet metal flat patter default view:
      oView4 = oSheet.DrawingViews.AddBaseView(oPartDoc, oPoint4, _
ViewScale,kIsoTopRightViewOrientation,kHiddenLineRemovedDrawingViewStyle, kSheetMetalFlatPattern, _
Camera1)'"sheetmetalflatpattern")'oBaseViewOptions)
'--------------------end of iLogic code-------------------------
Perhaps you can try my code. Note that you must launch this rule from within a model sheet metal .IPT file only. It will not work if you to try launching with an IDW or a non sheet metal part IPT open.
Perhaps Autodesk can help out to define the proper access code to the Sheet Metal Flat Pattern View. Further, how to define to show Tangent Edges in a formed view.
Thank you for your efforts.
Raj
MegaJerk
That code was for VBA and not ilogic. I will try to make some ilogic code for you tomorrow (or later today if I have time).
GitHub
mbranderhorst
Did you ever get this to work? If so could you please post it as I would also like to get this to work.
Thanks in advance.
philip1009
I'm not sure if this will work for 2012, but this is the sample provided by 2019 Inventor:
SyntaxEditor Code Snippet
Dim oSheet As Sheet
oModel = ThisApplication.Documents.Open("C:\temp\SheetMetal.ipt", False)
oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
kDefaultViewOrientation, kHiddenLineRemovedDrawingViewStyle, , , oBaseViewOptions)
Basically at the end of the Add Base View command there's a section for adding additional options specific to sheet metal, weldments, iPart/iAssembly, Positional, and Presentation views.  As you see in the middle of the sample it creates a Name Value Map and adds the option of SheetMetalFolded=False, then that argument is used in the drawing view creation where False means Flat.
Cody.Redding
 You just needed to create the NameValueMap and assign the correct variable.  You were very close.
Note: Per the 2017 API guide, this will only place the flat view, if it already exists in the part.  If it does not exist, then it will place a folded view.
Dim oSheet As sheet
Else
ViewScale,kIsoTopRightViewOrientation,kHiddenLineRemovedDrawingViewStyle, , ,oBaseViewOptions)
