sheet metal flat pattern total loop length
Message 1 of 18
Is there anyway to return this value using Ilogic or other non manual method? I can do it manually with the measure tool but ideally would like it to appear in the BOM.
Replies (17)
Message 2 of 18
WCrihfield
To clarify...you are wanting the total perimeter length of the outside edges of the flat pattern, right? (not including any interior holes or cutouts?)
The Flat Pattern Width, Flat Pattern Length, and Flat Pattern Area (items 44,45, & 46) are all available in the iProperties, under the "Design Tracking Properties" set. But I don't think there is a pre-existing iProperty for the Perimeter.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 18
Hi. No, all internal profiles also.
When you flat pattern a part and select measure, when you then click the
face it gives a Total Loop Length. It's this I want to read.
Message 4 of 18
WCrihfield
Here's some iLogic code you can use.  In the MsgBox, I'm dividing by 2.54 to convert centimeters to inches.
To just get the Perimeter, you can change the loop, to simply checking if the oEdgeLoop.IsOuterEdgeLoop, then use that one in your MsgBox.  You could also put checks at the top to check DocumentTypeEnum and SubType, if you wanted.
Dim oSMDoc As PartDocument = ThisApplication.ActiveDocument
Dim oSMDef As SheetMetalComponentDefinition = oSMDoc.ComponentDefinition
If oSMDef.HasFlatPattern = False Then
	MsgBox("There is no Flat Pattern yet.", vbOKOnly, "NO FLAT PATTERN")
	Return
Dim oTopFace As Face = oSMDef.FlatPattern.TopFace
Dim oMeasureTools As MeasureTools = ThisApplication.MeasureTools
Dim oLoopLength As Double = 0
For Each oEdgeLoop As EdgeLoop In oTopFace.EdgeLoops
	oLoopLength = oLoopLength + oMeasureTools.GetLoopLength(oEdgeLoop)
Next
MsgBox("Loop Length = " & oLoopLength/2.54)
I hope this helps.
If this solves your problem, or answers your questions, please click 'Accept As Solution".
Or, if this helps you reach your goal, please click 'LIKES" 👍.
Also, if you're interested, here are a few of the 'Ideas' I'd like to get implemented.
If you agree with any of them, please vote for them.
  • Add more capabilities to the 'Customize' dialog box (exe. Add Tab & Add Panel) Click Here
  • MessageBox, InputBox, and InputListBox Size & Format Options Click Here
  • Constrain & Dimension Images In Assembly Sketches & Drawing Sketches (TitleBlocks & SketchedSymbols) Click Here
  • Save Section View Status In DesignViewRepresentation (So It Can Be Used In The Drawing) Click Here
  • Add SolidBodies Folder In iLogic Rule Editor Model Tab Click Here
  • Convert All Views To Raster Before Autosave Stores To 'OldVersions' Folder Click Here
  • SetDesignViewRepresentation - Fix limitations for DrawingView of a Part Click Here
  • Create DocumentSubTypeEnum Click Here
Inventor 2020 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
Message 5 of 18
k14348
    Hope this will work.
Sub LoopLength()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCmpDef As SheetMetalComponentDefinition
    Set oCmpDef = oDoc.ComponentDefinition
    Dim oFp As FlatPattern
    Set oFp = oCmpDef.FlatPattern
    Dim oBf As Face
    Set oBf = oFp.BaseFace
    Dim i As Integer
    Dim Result As Single
    Result = 0
    For i = 1 To oBf.EdgeLoops.Count
    Dim oEl As EdgeLoop
    Set oEl = oBf.EdgeLoops.Item(i)
    Result = (ThisApplication.MeasureTools.GetLoopLength(oEl) * 10) + Result
    Next
    MsgBox (Result)
    Dim textValue As Single
    textValue = Result
    Dim oName As String
    oName = "LoopLength"
    Dim oCProp As PropertySet
    Set oCProp = oDoc.PropertySets.Item("Inventor User Defined Properties")
    Dim oProp As Property
    Set oProp = oCProp.Add(textValue, oName)
End Sub
-Karth
Message 6 of 18
Hi, the below works really well adapting it to write to Custom Iproperties. Is there a way to drive this from assembly level so I don't have to manually add a rule to each part?
Return
Next
iProperties.Value("Custom", "TOTAL_LOOP_LENGTH") = Round(oLoopLength*10)
Message 7 of 18
k14348
Sub Assyupdate()
Dim openDoc As AssemblyDocument
Set openDoc = ThisApplication.ActiveDocument
Dim doc As PartDocument
For Each doc In openDoc.AllReferencedDocuments
If doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
Set oCmpDef = doc.ComponentDefinition
Dim oBf As Face
Dim i As Integer
Result = 0
Dim oEl As EdgeLoop
Next
textValue = Result
Dim oName As String
Set oCProp = doc.PropertySets.Item("Inventor User Defined Properties")
Next
End Sub
Message 8 of 18
Hi, thanks but I'm getting the following error message:
Error in rule program format:
All other sub's or functions must be after Sub Main()
Message 9 of 18
WCrihfield
Try this.
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oEdgeLoop As EdgeLoop
Dim oCustPropSet As PropertySet
Dim oProp As [Property]
Dim oPropName As String = "TOTAL_LOOP_LENGTH"
Dim oPropValue As Double
Dim oExists As Boolean  = False
For Each oRefDoc As Document In oADoc.AllReferencedDocuments
	If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		If oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Document SubType Name").Value = "Autodesk Inventor Sheet Metal Part" Then
			oSMDoc = oRefDoc
			oSMDef = oSMDoc.ComponentDefinition
				Return
			oTopFace = oSMDef.FlatPattern.TopFace
			oLoopLength = 0
			For Each oEdgeLoop In oTopFace.EdgeLoops
			Next
			oPropValue = Round(oLoopLength * 10)
			oCustPropSet = oSMDoc.PropertySets.Item("Inventor User Defined Properties")
			For Each oProp In oCustPropSet
				If oProp.Name = oPropName Then
					oExists = True
					oProp.Value = oPropValue
			Next
			If oExists = False Then
				oCustPropSet.Add(oPropValue, oPropName)
Next
I hope this helps.
Wesley Crihfield
Message 10 of 18
Sorry no can't get this to work. Rule runs with no errors but nothing is written to any sheet metal parts.
Message 11 of 18
A message box placed below this line doesn't appear when the rule is run but does when placed above.
Message 12 of 18
JhoelForshav
@Anonymous
try changing it to:
If oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Document SubType Name").Value = "Sheet Metal" Then
Or
If oRefDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
That should work 🙂
Message 13 of 18
Hi ,
The first suggestion works thanks.
However, if there is a sheet metal part without a flat pattern  then the process fails and ideally id like it to then flat pattern the relevant part and continue instead of returning a message.
Return
I have the below but not sure how to incorporate it into your rule?
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
oDoc.Save
oDoc.Close
Message 14 of 18
JhoelForshav
Hi @Anonymous
Try this 🙂
I also turned off screen updating in the application while unfolding the part so you dont have to see it open the part and unfold it. Also reactivated the assembly document after.
			oSMDoc = oRefDoc
				Try
					ThisApplication.ScreenUpdating = False
					oSMDef.Unfold
					ThisApplication.ScreenUpdating = True
				Catch
				End Try
				ThisDoc.Document.Activate
			oLoopLength = 0
			Next
					oExists = True
			Next
Next
iLogicVb.UpdateWhenDone = True
Message 15 of 18
JhoelForshav
This is better. Doesnt leave the document that we had to unfold open...
			oSMDoc = oRefDoc
				Try
					oSMDef.Unfold
					cDef = ThisApplication.CommandManager.ControlDefinitions.Item("PartSwitchRepresentationCmd")
					cDef.Execute
				Catch
				End Try
				oSMDoc.Close
			oLoopLength = 0
			Next
					oExists = True
			Next
Next
Message 16 of 18
Donna_Fleming
Sorry. I meant to reply to Jhoel Forshav.
Message 17 of 18
Donna_Fleming
I know it's been a year, but thank you for providing this code.  It gets me a long way to where we need to be. We are asked to provide the total cutting inches required for the assembly. Would you be willing to add to this code so it totals the loop lengths for each piece to create a custom property in the assembly?
Message 18 of 18
Donna_Fleming
I found some code by Curtis W. in another forum that worked for me to get a total of all the values created by the code @JhoelForshav  wrote. This is my complete rule combining the code of these two fine gentlemen:
Dim oPropName As String = "LOOP_LENGTH"
			oSMDoc = oRefDoc
				Try
					oSMDef.Unfold
					cDef.Execute
				Catch
				End Try
				oSMDoc.Close
			oLoopLength = 0
			Next
			oPropValue = oLoopLength/2.54
					oExists = True
			Next
Next
'clear the custom property in the assembly
iProperties.Value("Custom", "TOTAL_LOOP_LENGTH") = 0
'set a reference to the assembly component definintion.
'This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
'check for and skip virtual components
'(in case a virtual component trips things up)
If Not TypeOf oOccurrence.Definition Is VirtualComponentDefinition Then
'custom property in the assembly
xNumber = iProperties.Value("Custom", "TOTAL_LOOP_LENGTH")
'custom property in the parts
yNumber = iProperties.Value(oOccurrence.Name, "Custom", "LOOP_LENGTH")
sumNumber = xNumber + yNumber
'set custom property values
iProperties.Value("Custom", "TOTAL_LOOP_LENGTH") = sumNumber
Else
Next
It works for me. If you have problems with it, I am sorry but my skills are not good enough
to solve your issue. I'm pretty much just a borrower of code at this stage and rely heavily
on gracious people who share their skills.
in
