Sheet Metal Flat export with OuterProfileLayer in Layer 0
Leonardo_Czuy
Message 1 of 11
Leonardo_Czuy
Hello everyone, I'm having some issues exporting the flattened sheet, where some flattening results are causing the OuterProfileLayer to appear on Layer 0.
			Dim sOut As String
			sOut = "FLAT PATTERN DXF?AcadVersion=2010&" & _
			"OuterProfileLayer=CONTORNI&OuterProfileLayerColor=255;255;0&" & _
			"InteriorProfilesLayer=CONTORNI&InteriorProfilesLayerColor=255;255;0&" & _
			"TangentLayer=SOTTILI&TangentLayerColor=255;0;0&" & _
			"BendLayer=SOTTILI&BendLayerColor=255;0;0&" & _
			"BendUpLayerColor=255;0;0&BendDownLayerColor=255;0;0&" & _
			"RebaseGeometry=True&" & _
			"InvisibleLayers=IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN"
			oCompDef.DataIO.WriteDataToFile(sOut, oDataMedium.FileName)
			AddDXFProperties(oDrawDoc, oDataMedium.FileName, quantidadeDePecas, False)
Replies (10)
Message 2 of 11
jeremy.goenen
Did you perhaps used a MarkFeature in the Part where you have the problem?
Fanden Sie diesen Beitrag hilfreich? Fühlen Sie sich frei, diesen Beitrag zu liken.
Wurde Ihre Frage erfolgreich beantwortet? Klicken Sie dann auf die Schaltfläche LÖSUNG AKZEPTIEREN
Inventor Versionen:
2025.2
Message 3 of 11
Leonardo_Czuy
@jeremy.goenen Hello.
No, i didn't use Mark Feature.
Message 4 of 11
jeremy.goenen
Hello @Leonardo_Czuy
can you share a file where the problem occurs?
Inventor Versionen:
2025.2
Message 5 of 11
Leonardo_Czuy
@jeremy.goenen hello, thats file
Message 6 of 11
jeremy.goenen
i get this Dxf when using your SOut, but that's how it shoul'd be no?
Inventor Versionen:
2025.2
Message 7 of 11
Leonardo_Czuy
@jeremy.goenen sorry i pass wrong file.
Message 8 of 11
jeremy.goenen
If i resolve the overlapping error in the flatpattern the output is as expected.
Edit:
I assume there is no OuterProfileLayer in this case since the Profile is not clearly defined
Inventor Versionen:
2025.2
Message 9 of 11
Leonardo_Czuy
@jeremy.goenen
Any idea of what might be wrong here?
Message 10 of 11
jeremy.goenen
it is the "Double" OuterProfile
Inventor Versionen:
2025.2
Message 11 of 11
Leonardo_Czuy
@jeremy.goenen
Any ideas on what can be done to bypass this?
