Sheet.CopyTo Method
Sheet.CopyTo Method
Sheet.CopyTo Method
I'm trying to use the method Sheet.CopyTo to export each sheet of an Inventor DWG multi-page, but I can not. Error messages are displayed in the annex. At first I thought that this method is only compatible with non-DWG IDW and Inventor. But, I tested the code below into a file IDW and not succeeded.
Any suggestions?
Public Sub ExportSheets()
    Dim oSourceDocument As DrawingDocument
    Set oSourceDocument = ThisApplication.ActiveDocument
    Dim oNewDocument As DrawingDocument
    Dim sNewDocument As String
    Dim sNewDocumentPath As String
    Dim sDrawingTemplateFile As String
    sDrawingTemplateFile = "C:\Arquivos de programas\Autodesk\Inventor 2010\Templates\Standard.dwg"
    sNewDocumentPath = "C:\Arquivos de programas\Autodesk\Inventor 2010\Samples\Models\Assemblies\Suspension\"
    Dim oSheet As Sheet
    Dim sSheetName As String
    Dim vSheetNameParts As Variant
    For Each oSheet In oSourceDocument.Sheets
        sSheetName = oSheet.Name
        vSheetNameParts = Split(sSheetName, ":")
        sSheetName = vSheetNameParts(0) & "_" & vSheetNameParts(1)
        'Criação de novo documento DWG
        sNewDocument = sNewDocumentPath & sSheetName & ".dwg"
        'Details: I found that there is an enumerator for Inventor DWG files, just to IDW.
        Set oNewDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, sDrawingTemplateFile, False)
        Call oNewDocument.SaveAs(sNewDocument, False)
        'oNewDocument.Close
       'Copy the active sheet - When you run the line under the mistakes happen.
        Call oSheet.CopyTo(oNewDocument)
    Next
    MsgBox "Folhas exportadas com sucesso!", vbInformation, "Exportação de Folhas"
End Sub
Ari Monteiro
Dharma Sistemas
YuhanZhang
Does the first Sheet in the oSourceDrawing have AutoCAD Blocks? Note that this is not supported to copy a Sheet with AutoCAD Blocks to another drawing document even via UI operations. You can add a check for the AutoCAD Blocks before copy the sheet to another drawing document.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
I don't have AutoCAD Blocks in the oSourceDrawing. My DWG files were created fully in Inventor. So, if the problems are AutoCAD Blocks, why this method does't work in IDW files?
Ari Monteiro
Skynet
YuhanZhang
Can you supply a sample document, or snapshot of the sheet?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
cburton72
Have you activated the sheet?
sheet.Activate()
k14348
     When u save copy as multipage idw to acad file it will be saved  each sheet basis only. then y we need this. ex.
-Karth
