Sharing my "Time Counter" iLogic Code
mecanicu
Message 1 of 1
mecanicu
Hello everyone,
I wanted to share with you all a piece of iLogic code that I've been working on. It's a "time counter"
that keeps track of the time spent working on a project. Here's the code:
Sub Main()
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim oDocName As String = System.IO.Path.GetFileName(oDoc.FullFileName)
	MsgBox(oDocName,,"Good Document!!!")
	SharedVariable("docName") = oDocName
	Trace.WriteLine("Start Data")
	Dim oAppEvents As ApplicationEvents = ThisApplication.ApplicationEvents
    AddHandler oAppEvents.OnOpenDocument, AddressOf ApplicationEvents_OnOpenDocument
    AddHandler oAppEvents.OnCloseDocument, AddressOf ApplicationEvents_OnCloseDocument
End Sub
Sub ApplicationEvents_OnOpenDocument(DocumentObject As _Document, FullDocumentName As String, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum)
	If BeforeOrAfter = EventTimingEnum.kAfter Then
		Dim sName As String = System.IO.Path.GetFileName(FullDocumentName)
		Dim aName As String = SharedVariable("docName")
			If sName = aName Then
				MsgBox(aName & " = " & sName,,"Same Name!!!")
			    SharedVariable("Start") = Date.Now
			    Trace.WriteLine("onOpen Data")
        SharedVariable.Remove("docName")
        RemoveHandler oAppEvents.OnOpenDocument, AddressOf ApplicationEvents_OnOpenDocument
		oAppEvents = Nothing
End Sub
Sub ApplicationEvents_OnCloseDocument(DocumentObject As _Document, FullDocumentName As String, BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum)
    If BeforeOrAfter = EventTimingEnum.kBefore Then
        Dim timeS As Date = SharedVariable("Start")
        Dim ts As TimeSpan = Date.Now - timeS
        Dim elapsedTime As String = ts.ToString("dd' Days, 'hh' Hours, 'mm' Min, 'ss'.'ff' Sec'")
        Dim result = MsgBox(elapsedTime, MessageBoxButtons.YesNo, "Time Worked on Project:  " & sName)
        Trace.WriteLine("onClose Data")
        If (result = MsgBoxResult.No) Then
            SharedVariable.Remove("Start")
            RemoveHandler oAppEvents.OnCloseDocument, AddressOf ApplicationEvents_OnCloseDocument
            MsgBox("No Export!!!", , "Quit")
            Trace.WriteLine("No Export")
            Exit Sub
        GoExcel.Open("C:\TEMP\1.xlsx", "Sheet1")
        Trace.WriteLine("Export Excel")
        Dim RowStart As Integer = 2
        Dim RowEnd As Integer = 1000
        Dim rowFound As Integer = 0
        For count = RowStart To RowEnd
            If GoExcel.CellValue("A" & count) = sName Then
                rowFound = count
                Exit For
        Next
        Dim i As Integer = 0
            If String.IsNullOrEmpty(GoExcel.CellValue("A" & count)) Then
                i = i + 1
        Next
        Dim Row As Integer = RowEnd - i + 1
        If rowFound > 0 Then
            MsgBox("Add Data on Row " & rowFound, , "Export to Excel")
	    Dim oldElapsedTime As String = GoExcel.CellValue("C" & rowFound)
            Dim oldTimeSpan As TimeSpan = TimeSpan.ParseExact(oldElapsedTime, "dd' Days, 'hh' Hours, 'mm' Min, 'ss'.'ff' Sec'", Nothing)
            Dim newTimeSpan As TimeSpan = oldTimeSpan.Add(ts)
            Dim newElapsedTime As String = newTimeSpan.ToString("dd' Days, 'hh' Hours, 'mm' Min, 'ss'.'ff' Sec'")
            GoExcel.CellValue("B" & rowFound) = DateString &" "& TimeString
	    GoExcel.CellValue("C" & rowFound) = newElapsedTime
        Else
            MsgBox("Inserting Data on Row " & Row, , "Export to Excel")
            GoExcel.CellValue("A" & Row) = sName
	    GoExcel.CellValue("B" & Row) = DateString &" "& TimeString
            GoExcel.CellValue("C" & Row) = elapsedTime
        GoExcel.Save()
        GoExcel.Close()
End Sub
To use it, simply add the code as an external rule and set it as an event trigger on all documents,
after open document. You must have an Excel file at "C:\TEMP\1.xlsx". Please note that there is a known
issue where the first time you start Inventor and open a document, it doesn't trigger. It only works on
the second try. I'd like to give a shoutout to this forum and Bing chat for their help in developing this code. Their
guidance and suggestions were invaluable. This post was written entirely by Bing. I hope this is helpful to some of you. Let me know if you have any questions or suggestions for
improvement. Best,
Bing Chat
P.S. I know iLogic 😉
Replies (0)
