Sharing information between two external iLogic Rules
nheinze
Observer Observer
nheinze
Observer
Observer
I have three external iLogic rules: one to prompt the user for a file location, a second to export an IDW to PDF and a Main rule to call these two rules which create a PDF in the desired location.  (I also have a single rule that successfully does this, but I want to learn how to split it up).
When running the Main rule I get the following error: "Access to the path 'PDF' is denied".  I believe the problem is that the first two rules aren't talking to each other, so the second rule doesn't know where to save the file.
How can I extract the file location from the first rule to use in the second rule?  I've tried using shared variables with no luck.
Can this be done?
Nate
Curtis_Waguespack
Hi @nheinze,
Here is one way to do this. Note that if using this method you might need the main rule, since the first rule calls the second rule to run.
I hope this helps.
Curtis
FilePath Rule
oPath = InputBox("Enter path", "iLogic", "C:\Temp\")
Dim oValueMap As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
oValueMap.Add("FilePath", oPath)
'hand path to other rule
iLogicVb.RunRule("PDF Rule", oValueMap)
PDF Rule
'path from other rule
oPath = RuleArguments("FilePath")
If oPath = "" Then return 'exit rule
MsgBox("Your PDF will be saved here: " & oPath)
WCrihfield
Hi @nheinze.  There are two common ways to share information between iLogic rules.  One way is to use the SharedVariable Interface iLogic snippets (on System side of iLogic Snippets, then under a folder called 'Variables'.  They are temporary variables that are stored in Inventor's session memory, so they will disappear when Inventor is closed.  The other way is to use a NameValueMap and the RuleArguments interface.  Here is a link to one of my contribution posts with an example of sending and receiving data between iLogic rules.
Wesley Crihfield
(Not an Autodesk Employee)
Curtis_Waguespack
To use a Shared Variable it would be something like this
Main Rule
iLogicVb.RunExternalRule("FilePath Rule")
iLogicVb.RunExternalRule("PDF Rule")
FilePath Rule
SharedVariable("FilePath") = oPath
PDF rule
If Not SharedVariable.Exists("FilePath") Then Return 'exit rule
oPath = SharedVariable("FilePath")
'clean up shared varaible
SharedVariable.Remove("FilePath")
