Shape question that cannot be swept
shlim8WSNC
shlim8WSNC
When I removed Sketch3 with a sweep, it looks like the blue color in the picture below, with less removed. I want to remove Sketch3 along the cylinder's hole line with a sweep, but it's not working well. Is there a solution?
StuOG
You may be able to get that hole tidied up with sheetmetal features. Try making the cylinder out of a SM Contour Flange where the diameter is not completed (leave a 0.5mm gap). This gap will allow you to unfold the part. Then use the SM Cut function to cut your penetration normal (tick the box). Refold your part after this.
J-Camper
This is because the Face, formed from your circular extrusion cut, changes offset as it goes around.  In your file the face changes from 110mm to 126.67mm:
If you want a profile to transition proportionally, you can use a loft between 2 sketches for a quadrant then mirror the feature twice to get the other quadrants.
