SetToRotation question
I have written a little app. that copies an assembly for a location on the network to a local folder. I am placing the assembly into another assembly at 0,0,0 location. I want to place it spinning it about the Y axis 180deg. I also want to spin it around the Z axis at a specified angle. I hacked the example file to make what is below. It works but it will rotate the assembly in the same degree for each axis.... I need two different axies... how would i go about accomplishing this? the "oMatrix.SetToRotation" holds one value...how do I clear it to have another degree set current or????
Thanks for any help....
Bill
Private Sub cmd_Apply_Click()
'Public Sub AddOccurrence()
' Set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
' Set a reference to the transient geometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
' Create a matrix. A new matrix is initialized with an identity matrix.
Dim oMatrix As Matrix
Set oMatrix = oTG.CreateMatrix
'this calculates the overall width of the guard
RotAngle = 180 / Val(tb_Angle)
If opt_CW_Rotation.Value = True Then
' Set the rotation of the matrix for a 45 degree rotation about the Z axis.
Call oMatrix.SetToRotation(3.14159265358979 / RotAngle, oTG.CreateVector(0, 0, 1), oTG.CreatePoint(0, 0, 0))
' Set the translation portion of the matrix so the part will be positioned
' at (0,0,0).
Call oMatrix.SetTranslation(oTG.CreateVector(0, 0, 0))
ElseIf opt_CCW_Rotation.Value = True Then
Call oMatrix.SetToRotation(3.14159265358979, oTG.CreateVector(0, 180, 0), oTG.CreatePoint(0, 0, 0))
' at (0,180,0).
' Add the occurrence.
Dim oOcc As ComponentOccurrence
Set oOcc = oAsmCompDef.Occurrences.Add("C:locaton on hard drive", oMatrix)
Unload Me
End Sub
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Help-me-to-Mate-a-tube-outside-of-a-dr...
Boss, No Solution or no Support from AutoDesk Forum.  Waste, better switch to another 3D Apps.
Vladimir.Ananyev
To combine several transformations use Matrix.TransformBy() method. Look at the sample “UCS by transformation matrix API” in the Inventor API Help.
There is a very good presentation on Inventor math:
Author:  Brian Ekins
“How Deep is the Rabbit Hole? Examining the Matrix and Other Inventor Math and Geometry Objects.”
http://modthemachine.typepad.com/files/mathgeometry.pdf
http://modthemachine.typepad.com/files/demos.zip
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
