Setting the active standard, ActiveStandarsStyle
Hi
I have been working on a method to set the active standard from VBA in Inventor 11, but with no luck.
From help the property ActiveStandarsStyle should be able to get and set the active standard style.
I have managed to get the standard style name by:
oStyleName = oIDWDoc.StylesManager.ActiveStandardStyle.Name
but can't figure out how to set it.
Any suggestions?
Regards Claus
YuhanZhang
See below sample code:
Sub ChangeStandardStyle()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    oDoc.StylesManager.ActiveStandardStyle = oDoc.StylesManager.StandardStyles("Default Standard (ISO)")
    Debug.Print oDoc.StylesManager.ActiveStandardStyle.Name
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
So easy...! And it works.
Thanks a lot.
Ragards Claus
