Setting event trigger with ilogic rule
Hi there,
I'm currently working on an external ilogic rule that sorts parameter. This works without problems, but if i want to use this rule on existing IPT, i have to set the event trigger (before save doc) with the "parameter sort"-rule every time.
So my thought was to include a code that enables the "before save doc"-trigger and connects it to my "parameter sort"-rule.
The structure of the code would be:
Sub
if (before save doc)-trigger is disabled it should get enabled and then it should get connected with the "parameter sort"-rule
end sub
Hope you guys understand what i'm looking for.
Cheers,
Kame
mrattray
It is not possible to do this directly. The work around is to create a local rule that fires the external rule and add the local rule to your event triggers. It's not easy to do. There is a couple of threads here discussing this in detail, try doing some searching. I do have a rule that does do this, if you're still interested I'll dig it up and thrift it for you.
Mike (not Matt) Rattray
