SetDesignViewRepresentation error in Weldment
Mike_Dzwigalski
Mike_Dzwigalski
I made an iLogic rule which iterates through each of the components within an assembly and switches the design view to "Default" but when I attempt to run the rule in a weldment it errors out with "The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))". I have tested the code in a normal assembly and it performs as I had expected.
I still have to add coding to add "Default" in event it doesn't exist but I want to first solve this error.
When I look at the logger for the information I requested I notice it is looking at the weldment itself as an occurrence, then attempts to set the design view then errors out. Is this being done because it is a weldment?
The code I am using is below and I have added a test weldment.
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
Dim oAssyCompDef As ComponentDefinition
oAssyCompDef = oAssyDoc.ComponentDefinition
Dim oOccurrences As ComponentOccurrences
oOccurrences = oAssyCompDef.Occurrences
Dim oOcc As ComponentOccurrence
For Each oOcc In oOccurrences
	Logger.Info(oOcc.DefinitionDocumentType)
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		Logger.Info(oOcc.BOMStructure)
		Logger.Info(oOcc.Name)
		oOcc.SetDesignViewRepresentation("Default", , True)
		Logger.Info("Confirm If")
Next
JelteDeJong
Your assumption that welds are seen as occurrences is correct. You can skip the welds like this:
Dim oAssyDoc As AssemblyDocument = ThisDoc.Document
Dim oAssyCompDef As ComponentDefinition = oAssyDoc.ComponentDefinition
Dim oOccurrences As ComponentOccurrences = oAssyCompDef.Occurrences
For Each oOcc As ComponentOccurrence In oOccurrences
	If (oOcc.Definition.Type = ObjectTypeEnum.kWeldsComponentDefinitionObject) Then
		Dim weldOccDefinition As WeldsComponentDefinition = oOcc.Definition
		' This is impossible ;-)
		' weldOccDefinition.SetDesignViewRepresentation("Default", , True)
		MsgBox("Found a weld lets continue to the next oOcc")
		Continue For
	logger.Info(oOcc.DefinitionDocumentType)
		logger.Info(oOcc.BOMStructure)
		logger.Info(oOcc.Name)
		logger.Info("Confirm If")
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Mike_Dzwigalski
Thanks for the help!
