Set SketchCircle Radius to UserParameter
Currently I have some simple code to create a sketch and draw a circle. I have a UserParameter called ConduitRadius that I want to use to control the radius of my circle, but I can't find a way to set the radius to the parameter instead of just it's value. The .Radius/AddByCenterRadius only accepts a Double, so I can't use "ConduitRadius". I tried to create a DimensionConstraint, but there doesn't seem to be a way to change the parameter. It seems like this should be simple, but I can't find any answers.
Dim oDoc As Document = ThisDoc.Document
Dim oDef As ComponentDefinition = oDoc.ComponentDefinition
Dim StartPlane As WorkPlane = oDef.workplanes.item("StartPlane")
Dim StartPoint As WorkPoint = oDef.workpoints.item("StartPoint")
Dim PointProxy As Point2d = ThisApplication.TransientGeometry.CreatePoint2d()
Dim StartSketch As PlanarSketch = oDef.sketches.add(StartPlane)
StartSketch.Name = "StartSketch"
Dim PointEntity As SketchPoint = StartSketch.AddByProjectingEntity(StartPoint)
Dim Circle As SketchCircle = StartSketch.SketchCircles.AddByCenterRadius(PointEntity, ConduitRadius)
'Circle.Radius = "ConduitRadius"
'Dim oRadius As RadiusDimConstraint = StartSketch.DimensionConstraints.AddRadius(Circle, PointProxy)
'oRadius.Parameter = "ConduitRadius"
I knew it was simple. Just needed to add .Expression to oRadius.Parameter. Found here https://forums.autodesk.com/t5/inventor-customization/create-ilogic-extrusion-and-drive-dimensions-w...
'StartSketch.Name = "StartSketch"
oRadius.Parameter.Expression = "ConduitRadius"
