set Sketch to reuse + VB.net or VBA
How can i set the Sketch to reuse?
please VBA or VB
thx
xiaoyan.qi
do you means you want to share a sketch?  the share sketch operation only works when the sketch is consumed by features.
Here is a simple VBA code
Sub makeSketchShared()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    Dim oSke As PlanarSketch
   ' "Sketch1" is the sketch name you want to reuse and consumed by features, change the name in your case
    Set oSke = oCompDef.Sketches.Item("Sketch1")
    oSke.Shared = True
End Sub
Let me know if it works
Mick
